Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
One way is to use an environmental sphere ... (The best is bagginsbill's envirosphere
He has a wonderful tutorial on his site as well ... You can use the lighting with the sphere ... and choose whether or not to add a sunlight as well, but there is a sun setting with bb's set-up. So, that may not be necessary.
You will need a ground plane and a transmap and texture map for PP11, since at the moment it does not incorporate a shadow catcher.
Boni
Nom!
The render ain't bad, either. :D
Wow ghostship!! That's exactly what I want to achieve! Did you use EZSkin3 for the character?
www.acrionx.com | My Freebies | My Store | My Youtube Channel
acrionx posted at 7:49PM Wed, 24 August 2016 - #4281011
No, I used my own PBR/Cycles SS skin shader. The new plugin for Ezskin3 works very well and looks a bit better than mine. He really did a great job on it.
freemarlie posted at 8:08PM Wed, 24 August 2016 - #4281018
Thank you! How long did that take to render?
a couple of hours because I ain't got a fancy computer or video card for GPU rendering.
to answer your original question: The best thing for the sky dome is an actual HDR image. These are 32bit images not the normal 8 bit we use for jpgs. You can use old 8 bit images but they do not give you the same level of contrast on the figure that the 32 bit HDR's do. Here is a link to a bunch of free ones that are pretty good.
http://www.hdrlabs.com/sibl/archive.html
That's a great resource Ghostship2. I'm still looking for some good (free) night skies. Having trouble tracking them down. Any ideas?
________________________________
Thank you both for pointing those out. I'm gonna give them a try.
I want to render outdoor scenes. How do I set up a sky dome and get the proper lighting?
