Fri, Nov 22, 9:27 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: AVX Optimized?
Mari-Anne ( ) posted Mon, 01 August 2016 at 12:36 PM · edited Fri, 22 November 2024 at 9:27 PM
How can I tell if I am running the AVX optimized or AVX non-optimized version of Vue Infinite 2015?
glaseye ( ) posted Fri, 26 August 2016 at 4:35 PM
In Vue, select the help button on the top menu, and then choose the 'about vue' option. In the window that appears at the right bottom it shows wich build you are running ,,,
Mari-Anne ( ) posted Sat, 27 August 2016 at 9:34 AM
Thank you, glaseye. Can you also tell me what exactly AVX optimized means?
glaseye ( ) posted Sat, 27 August 2016 at 9:56 AM · edited Sat, 27 August 2016 at 9:57 AM
I'm afraid it's to complicated for me to explain... but basically AVX is an extra set of commands build into newer CPU's. So by using AVX, Vue should be somewhat more efficient... (faster).
http://www.e-onsoftware.com/support/forum/viewtopic.php?f=2&t=8648
https://en.wikipedia.org/wiki/Advanced_Vector_Extensions
Mari-Anne ( ) posted Sat, 27 August 2016 at 10:06 AM
Thanks, I really appreciate your help.My computer is about 1 year old so I am assuming it is capable of supporting the AVX commands. I'll probably never notice the difference, but I have always wondered about it.
glaseye ( ) posted Sat, 27 August 2016 at 10:14 AM
Your welcome ... (and indeed, don't expect miracles from AVX; I've got no clue what functions in Vue benefit from AVX, so no idea how much performance is improved by it.... but every little bit helps.... If there is one thing I've learned from Vue, it is patience 😁 )
