Tue, Feb 4, 9:54 AM CST
Subject: Changing the color of the Poser Window?
dvitola ( ) posted Sat, 26 July 2014 at 2:37 PM · edited Tue, 04 February 2025 at 7:36 AM
Is there a way to permanently change the brown color of the Poser window? I know I can flood fill for a temporary look, but I want to change it to white permanently. The brown is just hard for me to deal with anymore. I have PoserPro 2014. Thanks in advance!
Denise
EClark1894 ( ) posted Sat, 26 July 2014 at 4:15 PM
Quote - Is there a way to permanently change the brown color of the Poser window? I know I can flood fill for a temporary look, but I want to change it to white permanently. The brown is just hard for me to deal with anymore. I have PoserPro 2014. Thanks in advance!
Denise
When you say "Poser Window" are you refering to the preview window? If so, then yes you can set the background and foreground colors to white, go to "Preferences" and under the tab for "General Preferences",  you'll find "Launch Behaviour". Check the button marked "Launch to preferred scene". Then click on the larger button "Set Preferred Scene". Click okay and close the Preferences window. This will only change the Foreground and Background colors. I believe you can also set the shadow colors as well. I couldn't get the ground prop to launch to any other color. Sorry.
dvitola ( ) posted Sat, 26 July 2014 at 8:16 PM
Thank you so much! That worked.
BassX ( ) posted Mon, 19 September 2016 at 3:12 PM
Hold Shift / Command Key. then click on the background board area. A color window should pop up. Select color, then select OK
