Wed, Nov 20, 5:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 4:32 am)
Subject: How to change the inherent position of an object?
AsteroidLady ( ) posted Mon, 19 September 2016 at 2:49 PM ยท edited Sun, 17 November 2024 at 3:35 AM
I apologize once again for my ignorance. If I am importing a prop that was not originally made for Poser, I know how to tell Poser to import it at the scale and position I want. But then if I use the original obj to make morphs for the prop, then the morph also moves and resizes the prop. I fixed the scale part of it by using the Objaction Scaler pre-import. Now the morphs no longer make the object grow bigger, but they still move it. What is the equivalent for position?
Boni ( ) posted Mon, 19 September 2016 at 3:07 PM
So our master modelers can help you. Could you go through a step-by-step process to show how this is "not" working for you?
Boni
AsteroidLady ( ) posted Mon, 19 September 2016 at 3:33 PM
The obvious solution finally occurred to me right after I posted that. Export from Poser, and use that obj to make morphs. Don't know why it took me so long to think of it. I had been trying to use the original pre-imported version.
Boni ( ) posted Mon, 19 September 2016 at 3:40 PM
๐Ÿ‘ I'm so glad you found a solution. We all have our moments. I don't recall what the process was, but I spent months trying to work through a process and askibg all over the forums for help ... only to have answers I didn't understand and posters that didn't understand my question. Why, because the situation I thought was a problem didn't exist ... I was looking at it without seeing the whole picture as it were. Of course this was more elaborate than your question. I still blush a little over it ... even though I don't recall what exactly I was obsessed with. Probably a mental block to my own misconceptions.
Boni
