Sun, Jan 5, 1:10 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: USGS DEM Files In Carrara?
Steve K. ( ) posted Wed, 21 September 2016 at 7:51 PM · edited Sun, 05 January 2025 at 8:51 AM
I haven't done my homework here so apologies ...
I recently upgraded my VUE Complete and was browsing through the examples when I saw a DEM landscape render. DEM's are real world data files representing landscapes. I had been struggling to create the San Francisco peninsula and the Bay in Carrara, and decided to give VUE a try. Worked great, Google found the DEM file and VUE did the rest. I found an old link showing that Carrara can import DEM, but I have not tried it:
http://www.carls-corner.net/tutorials/C4_DEM_GrndCntrl/C4_DEM_tute.htm
Anybody tried this? If its troublesome, I'm thinking maybe I can export the landscape mesh from VUE as an OBJ ... or something ...
Mythic3D ( ) posted Wed, 21 September 2016 at 8:12 PM
I believe you need Digital Carver's "Ground Control" plugin to use DEM files. I looked into it a little bit a few months ago but I've never managed to even successfully download a DEM file (every site I found for them was either defunct, very confusingly setup or required a login) so I never bought the plugin and don't know how hard to use it is.
MarkBremmer ( ) posted Wed, 21 September 2016 at 9:04 PM
You can DEMs from the USGS site. Ground Control handles them rather nicely.
Steve K. ( ) posted Wed, 21 September 2016 at 9:06 PM
Thanks for the reply. I think I'll stick with VUE for now ... I can do the wide landscape shots there, and the closer shots in Carrara ...
Here is where I found the San Francisco DEM's, I downloaded the "San Francisco North" file, including the Golden Gate, the Peninsula, and Alcatraz Island, all of which are part of my animation. It downloads as a text file, which you have to convert to a *.dem file by getting Windows to delete the *.txt extension. Windows Explorer can do this if you kick it hard enough ...
http://www.lib.berkeley.edu/EART/dem/dem.html
wheatpenny ( ) posted Thu, 22 September 2016 at 6:01 PM
Site Admin
I have the Ground Control plugin. It works flawlessly, just load the DEM and it imports right away with no difficulty.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Steve K. ( ) posted Thu, 22 September 2016 at 7:07 PM
OK, $30 is affordable. If I get frustrated trying to get my Poser items into VUE (supposed to work with the latest VUE), I'll get it. I'm way more comfortable working in Carrara anyway. Although I have to say VUE does great landscapes. Here is a render based on a VUE tutorial in 3D World years ago:
http://pre01.deviantart.net/87df/th/pre/f/2010/307/1/3/vue_8_test_render_by_cplneverlast-d324163.jpg
wheatpenny ( ) posted Thu, 22 September 2016 at 7:27 PM
Site Admin
Vue 2015 imports Poser models well too, but it doesn't recognise Poser 11, just 10/Pro2014 and earlier (when you set up the Poser importer for Poser 10 or Pro 2014 use the 2013 SDK).
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
Steve K. ( ) posted Thu, 22 September 2016 at 10:16 PM
wheatpenny posted at 10:01PM Thu, 22 September 2016 - #4284435
Right, I had trouble with whatever combination I had, but now I have VUE 2015 and Poser Pro 2014. Thanks for the tip on the SDK. But I still cannot animate Poser content in VUE, right? I.e. I can only import animations done in Poser itself?
This kind of problem is why I like Carrara, virtually all my Poser content loads seamlessly from Carrara's browser, and can be animated in Carrara. No Poser needed. Admittedly its mostly older content, e.g. Gen4 characters & clothes - I've read some newer Poser content is different.
A humorous aside, the first thing I put on a new machine is Poser 7, to get its Runtime for Carrara: M4, V4, etc., none of which I think is included in later Poser versions.
