Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
willshetterly posted at 5:44PM Thu, 22 September 2016 - #4284296
Do you know if you have V4 installed in more than one runtime? I understand that can cause trouble.
No, I know that I do not. Just the one.
In the same place where the bat file is there is also a .command file (actually 2 one for v4 and one for v4 to v3) which is the mac version of a bat file.
it is in the /Runtime/libraries/!DAZ/ folder
in my mac the full paths are: /Users/Shared/v4/Runtime/libraries/!DAZ/DzCreateExPFiles-V4.command ; exit; and: /Users/Shared/v4/Runtime/libraries/!DAZ/DzCreateExPFiles-V4V3.command ; exit;
If you correct the path to reflect your setup you could also just paste the above commands into your terminal at it will create/ initialize the files
sorry one mistake if you run form the terminal you need a slash in front of the !DAZ so the correct path is: /Users/Shared/v4/Runtime/libraries/!DAZ/DzCreateExPFiles-V4V3.command ; exit; and: /Users/Shared/v4/Runtime/libraries/!DAZ/DzCreateExPFiles-V4.command ; exit;
or just double click the .command file in the folder itself.
david_macrae posted at 9:35AM Fri, 23 September 2016 - #4284466
Fantastic! I'm on it!
I meant backslash so it looks like this "/!DAZ/" as the ! needs to be escaped anyway I just noticed that this forum keeps deleting the escape backslash every time I post it. very strange. I did type it correctly then I corrected myself only to find it messed up again at so I am trying things here to see what works maybe quotes. because if you cut and paste the command into the terminal on a mac it will not work without the back slash.
"/Users/Shared/v4/Runtime/libraries/!DAZ/DzCreateExPFiles-V4.command ; exit;"
without quotes
Ahh I get it. The forum is probably running stripslashes. So no back slashes allowed "well a pain if we try to use code snippets."
anyway sorry if I confused anyone. you can just fint the .command file and click on it.
@ngsf there are manny poser native characters including Paul and Pauline which are the newest characters in Poser 11. This thread was specifically asking aabout V4 on a mac computer.
I personally use her a lot as well as A3 and m4 and H3. as well as many other figures including those that come with natively with Poser.
Well, I think I did everything right and every file is where it's supposed to be. But when I try to run the .command file to initialize V4.2, I'm told I don't have the correct permissions to run it. I checked the permissions on the file and I do, indeed, have full read & write permissions, but it still won't run. Just for kicks, I made a duplicate of the file, and that actually opened and ran in Terminal. But the operation will not complete. It gets most of the way through and simply stops. I've re-downloaded the file a couple of times, cleared everything and started from scratch, with no result. Have to admit, I'm running out of ideas.
Hey all - I upgraded to Poser 11 a while ago and am only now trying to (manually) install Victoria 4.2 with all her morphs. I've managed to get every individual morph to load and they all work fine - but I can't seem to get any of her full-body morphs (Base, ++, Elite) to work. When I select the top of the hierarchy ("Body") I've got nothing. I can only morph individual body parts. What in the world could I be doing wrong?
