Tue, Jan 7, 12:52 AM CST
Subject: Graph Editor Poser Pro 11
arrow1 ( ) posted Wed, 28 September 2016 at 5:53 PM · edited Fri, 11 October 2024 at 8:20 PM
I posted this in the technical.So far no response.So I thought I would try here! I am having trouble with the Graph Editor.If I try to move backwards whilst trying to make an animation or make an accidental click Poser Pro 11 crashes! Has anyone else had this problem? If so I will send a bug ticket to Smith Micro. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Richard60 ( ) posted Wed, 28 September 2016 at 6:23 PM
Do you have any more specifics? I don't have a problem with the graph editor, but it could be that I am not doing what you are. What do you mean by moving backwards?
arrow1 ( ) posted Wed, 28 September 2016 at 7:11 PM
I animating a V4 Figure which is 810 frames long.I use the graph editor to make any movement changes such as forearm,hip and movements etc.In the UI if I click backwards on the timeline to make any changes Poser 11 Pro crashes. Also the graph lines are all over the place sometimes double up on one another! Can anyone tell me what the Selection Sync option is in the graph editor? When using Poser Pro 2014 and I do not have any problems! Cheers
Richard60 ( ) posted Wed, 28 September 2016 at 10:25 PM · edited Wed, 28 September 2016 at 10:26 PM
I just setup a scene with a V4 and 810 frames and moved back and forth with no issues.
If you have multiple layers you will see two lines one Red and one Black. The Red one is what you are moving on that layer and the Black one is the result of the results of what the layers are doing. If they are all set to add then each change on the layer will change the black line. If set to replace then only changes on the top most layer with movements of that single joint/movement will have an effect. So if you have 3 layers and Bend the Right thigh on Top layer then and Bend on the lower layers will be overridden. However the Right Thigh can be twisted on a lower layer and still have an effect since there is no twist on the top most layer.
The Selection Sync will keep that graph in sync with whatever body part is currently selected. With Poser11 you can have multiple graphs open so can jump back and forth between graphs without having to select the body part first. So you can have the Elbow / Wrist / Shoulder all open and move between the graphs to make a movement such as drinking a cup of tea a lot faster since you do not have to spend time selecting the proper joint first before making the adjustment.
Poser 2014 also has the layers option, but not the multiple graphs.
arrow1 ( ) posted Wed, 28 September 2016 at 10:51 PM
Many thanks for your reply.I do not know what is causes Poser Pro 11 to crash.Perhaps it is Windows 10! Cheers
