This design work for you? The base needs to be wider of course. Head rises and lowers to adjust for height of doll. Motor shaft rotates with off center belt attachments to make the vibrating action these machine are noted for. Ill be making the belt dynamic so it works with any doll, any shape and can be used in animation. I have no inclination to add in morphs to the belt for specific characters and their morph packs. If you truly require a belt for a specific character and morph pack such as V4 and her Morphs++ then you are on your own. I can add a readme that explains how to use the cloth room but if you are not willing then I'm done here and this will appear at a free site at some time in the near future. What you are asking for is a paid product due to all the work involved adding in morphs for various characters. That or you take the OBJ belt and add in the morphs you need for the characters you have yourself.
Looks good. How is it mapped....different materials zones or one map for all parts? Of course you are right....I will have to do some figuring on the belt. But if you include the instructions for using the dynamic belt I will try ti get through it. I just appreciate the gift and hope you don't think me ungratefully demanding for something you are taking time on and giving away free. Whatever you can do will be appreciated. Thanks. As far as the belt goes, from time to time might need it to be able to wrap around a couple together. I have been collecting and creating erotica and erotic fantasy art and pin-up art since 5th grade and that was a REAL LOOOOOONG time ago. I have a huge library of erotic clip art and framed originals and books I reference from to do my own work. In that collection are images from an old Mexican collection of couples in the machine together and wanted to try some of that. Face to face and front to back I guess the width of the belt is the same but what will have to change is the length. If you can keep that in mind when creating it I would appreciate it. Look forward to seeing what you come up with. Again, thanks! OH and BTW I think I mentioned it was for Poser since I do not have D/S nor do I want to invest in materials for it.
mat zones but I can give it a uv map in Blender. The dynamic belt is finished. Looks like the belt in the reference images. Base of machine width adjusted wider for stability. Dynamic belt with the triangular ends rigged to follow the off center cam that makes the vibrations. Paint your own bumps and textures. I just dumped some rough metal on it for illustration. It's on the other machine. I'll pack it up later this evening. Poser tested only.
Nice work there. Or rather, very nice work.
Greetings all. I have been working on a series of Vintage Pinups and have been finding items that would fit in with older pinup development shots. I need what was then called a Health Builder Machine. You can find it on Google but I have included two images form the time to show which machine I am referirng to. It would have to work in Poser of course and fit any figures from V2 to V4. The belt would need to pivot from the contact point with the motor to allow it to be wrapped around the buttocks, waist or breast areas and it would need to have some morphs to widen or narrow the width to accommodate those body parts. If anyone knows of something closely resembling this please let me know. Thanks.
