Fri, Jan 24, 7:16 PM CST
Subject: Looking for a Dynamic Cloth Tutorial
Kalypso ( ) posted Sun, 16 October 2016 at 1:47 PM · edited Fri, 24 January 2025 at 7:12 PM
Site Admin
I started using dynamic cloth with Poser 5/6 and had collected various tutorials but now I can't seem to find anything more advanced for doing certain things with the clothing like lifting up the edge of a skirt and so on. I'm pretty sure there is a more comprehensive tutorial out there for free or for sale but I can't seem to locate it. I don't want another beginner's one that shows you how to set up the simulation or what the parameters mean. If anyone one knows of advanced tutorials please point me in the right direction. Oh, and Esha's Master Class tutorial does not include these details for cloth and character interaction either.
Thanks!
Boni ( ) posted Sun, 16 October 2016 at 3:44 PM
Give me a couple days, I can collect some tuts on the cloth room for you, won't be back on my work machine until tomorrow.
Boni
Miss B ( ) posted Sun, 16 October 2016 at 4:05 PM
I have Esha's Cloth Room Master Class tutorial, but I'd be interested in other advanced tutorials as well.
_______________
Butterfly Dezignz
Boni ( ) posted Sun, 16 October 2016 at 11:01 PM
Thank you Miss B, that is a wonderful start.
Boni
FVerbaas ( ) posted Mon, 17 October 2016 at 12:47 AM
Forum Coordinator
If I remember well vertices in the 'choreographed' group follow object translations. So if you add the vertices at the place where you want to pick up the skirt to that group you may be able to lift thge skirt there. This method of course does not work for hybrid clothing where the skirt is say the hip actor and you can have only one animated action. You can grab the skirt in 2 locations but then these locations will have to move as one.
parkdalegardener ( ) posted Mon, 17 October 2016 at 5:21 AM
Look where you found the fur Boni. Lots of stuff including wind force as asked about in the other thread, Cloth room stuff including interacting characters with dynamic cloth and more
Boni ( ) posted Mon, 17 October 2016 at 6:07 AM
Thank you all! Will do. We have an amazing community here.
Boni
aRtBee ( ) posted Mon, 17 October 2016 at 10:57 AM
I made a bunch, some time ago
Boni ( ) posted Mon, 17 October 2016 at 12:15 PM
aRtBee, you are always on my list of resources, my friend! I have you bookmarked!!
Boni
Kalypso ( ) posted Mon, 17 October 2016 at 3:41 PM · edited Mon, 17 October 2016 at 3:45 PM
Site Admin
Thanks everyone, I had completely forgotten what I was supposed to be doing. I do have all those tutorials bookmarked or saved but for some reason I was being quite dense about it. Finally it clicked when I read this post in the Hivewire forum (not sure if I'm allowed to post here). In case anyone else is having the same problem it's in Forums: Learn and Practice: Software: Poser: Pulling Back the Drapes: The Cloth Room, a thread started by VortigensBane. So, here's my result:
In that thread VortigensBane says to move the whole prop so that the selected vertice in the choreographed group is where we want it in 3D space which is fine when you have only one point. My question is what happens if I have two separate vertices? For example I want my character to lift both sides of her dress and curtsey like this:
Has anyone done or found anything similar in a tutorial, preferably dumbed down and step by step. :) Thanks!
Oh, and I nearly forgot. In my attempt above the dress is being pulled from the torso which looks a bit unnatural. How can I get it to look as if it's being lifted only from the skirt part? When you lift below the hip the torso doesn't necessarily follow. Should I constrain the torso?
Miss B ( ) posted Mon, 17 October 2016 at 4:01 PM
Nicely done Kalypso. I think I would try Soft Decorated for the bodice (or whatever that mat zone is called), as it might be enough, though I see you don't have a seam at the waist, so not sure. If that doesn't work, you can always try constraining it, but again, without a separate bodice from the skirt, I don't know how that would work.
_______________
Butterfly Dezignz
Boni ( ) posted Mon, 17 October 2016 at 5:39 PM
As some of you may know, I am working on making a Webinar for the hair room at the moment, if this goes well my follow up will be for the cloth room. Just to let everyone know what's down the road.
Boni
Miss B ( ) posted Mon, 17 October 2016 at 5:49 PM
I look forward to seeing it. I've not played in the Hair Room, but there's always a first time. 😉
_______________
Butterfly Dezignz
Kalypso ( ) posted Tue, 18 October 2016 at 1:23 AM
Site Admin
Miss B thanks for the suggestion, I'm afraid I've botched it so now I'm thinking of doing the curtsey differently. Two separate animations and postwork is probably the route I'll go since no one really seems to know of any detailed tutorial for this stuff. I'm also thinking that maybe I should do a cloth room simulation to get the dress fitted on the pose and then maybe a bullet physics simulation to lift the ends of the dress?
Boni, thank you for doing the webinars. Could we get some more information on these? Will it be like SM's which is live and then recorded for those who can't attend?
FVerbaas ( ) posted Tue, 18 October 2016 at 5:23 AM · edited Tue, 18 October 2016 at 5:25 AM
Forum Coordinator
For 2-handed curtsey you could try to add two spheres, large enough not to 'slip' through the mesh of the skirt bur small enough not to show as a ball under the cloth, and then position them where you want the hand to grab the skirt. Then in simulation use the target tool to move the spheres to the hands. This should pull the cloth to the hand. Alternatively make the skirt a hybrid character with waist, hip and two 'arms' chind of hip to move the cloth. Let 'arms' each have one-facet geometry where you want to grab the skirt, rest of geometry is 'waist' and 'hip'. Make hip clothified body part. This should allow you to move the grip points as you like. All this not tested, sorry no access to system, but that is how you would go at this.
Boni ( ) posted Tue, 18 October 2016 at 6:50 AM
These Webinars will be hosted by Renderosity and YES they will be live and recorded for those who cannot attend.
Keep in mind Kalypso that in bullet physics there are "hulls" that the object collides against, not the actual geometry, therefore not as "close". Poser uses small convex shapes as it's hulls. Poser legacy dynamics uses calculus and the actual geometry. If that is an issue for you. Bullet Physics advantage is real time and that saves time, but accuracy is somewhat lost.
Boni
