Tue, Feb 4, 9:22 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Choppy shadow
mdbruffy ( ) posted Wed, 02 November 2016 at 5:39 PM ยท edited Tue, 04 February 2025 at 1:52 AM
This was rendered in Poser Pro 11 on Windows 10 64 bit. The outfit is the C-tunic for V4 converted with Wardrobe Wizard for V3. TRansparency on the sleeves and skirt is set at 2.0. Does anyone know how to fix this?
Boni ( ) posted Wed, 02 November 2016 at 5:43 PM
What render engine are you using? Firefly or Superfly? Also could you show a screenshot of the mat settings. That would help a lot.
Boni
mdbruffy ( ) posted Wed, 02 November 2016 at 6:02 PM
I always use Firefly. Here's the Material room set-up.This is the set-up for the tunic's long skirt. Material Room.jpg
jura11 ( ) posted Thu, 03 November 2016 at 1:54 AM
Hi there
This I've never seen in my life and I do render with several render engines Not sure why you are have there transparency set at 2.0,when you don't have there any map,can you try to render with transparency set at 0 and that model C-Tunic for V4 do have maps if yes can you try plug there transparency map from C-Tunic if there is or can you post the link on that model
Thanks,Jura
jura11 ( ) posted Thu, 03 November 2016 at 2:10 AM
OK I think I've that and rendered like you are with transparency set at 2.0 and I've got same or similar effect
But with transparency set at 1.0 this effect disappear or is not there,please try to use transparency set at 1.0
Hope this helps
Thanks,Jura
mdbruffy ( ) posted Thu, 03 November 2016 at 3:57 AM
Okay. I'll lower the setting. 2 usually works for me. but apparently not this time. Checking e-mails before going to work. I'll post the results when I get home.
jura11 ( ) posted Thu, 03 November 2016 at 11:49 AM
mdbruffy posted at 4:47PM Thu, 03 November 2016 - #4288707
Hi there
I always use for trans maps 1 and I've never tried 2,did you tried same scene in Poser 10/2014?
Hope this helps
Thanks,Jura
mdbruffy ( ) posted Thu, 03 November 2016 at 3:05 PM
I don't have P 10. tried it and could not get it to work for me. Went back to P9 till PP11 came out and as far as the program goes, I have not had any problems with it- it's rendered pics that P9 would have choked on. There have been times - in earlier programs- when a transparancy setting of 1 left faint outlines and I had to bump it up to 2 in order to clear things out. But this time going back to 1 did the job. Thanks jura11.
jura11 ( ) posted Thu, 03 November 2016 at 8:58 PM
mdbruffy posted at 1:23AM Fri, 04 November 2016 - #4288756
Looks much better there,no more chopped shadows at least You can try to experiment with lower transparency value,this depends on more factors and models etc Glad this worked for you there
Thanks,Jura
