Sun, Nov 24, 2:44 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: Poser GoZ issue
BlackTalonArts ( ) posted Thu, 03 November 2016 at 3:14 PM · edited Sun, 24 November 2024 at 1:02 PM
Ok, so I have Zbrush installed. Decided to give poser 11 Pro another go, so installed it today. Everything starts up fine, but when I try to export anything using the GoZ option from Poser it opens Zbrush and crashes (zbrush) immediately. I have no issues exporting items from DS to Zbrush using GoZ. Anyone have any ideas what the issue could be? Really would appreciate any input. Thanks! ~Mel My system is an iMac 3.4ghz i5 32gb ram, using the latest OS sierra GPU Nvidia GeForce 2gb
hborre ( ) posted Thu, 03 November 2016 at 9:28 PM
Did you install all the SRs?
BlackTalonArts ( ) posted Fri, 04 November 2016 at 3:30 AM
hborre posted at 3:30AM Fri, 04 November 2016 - #4288807
Yes I did
wimvdb ( ) posted Fri, 04 November 2016 at 7:30 PM · edited Fri, 04 November 2016 at 7:31 PM
I do not have a Mac, so i do not know if this is applicable to your situation, It sometimes happens that the communication between poser and zbrush is broken (for example when one of the two crashes in a GoZ operation).
In this case Poser can get confused and try to use the old info when you do GoZ again (after a restart).
This info is stored on WIndows in users/public/Pixologic in the GoZ folders. GoZApps/Poser has the links to poser, GoZBrush the last exported figure or props references, and GoZProjects/Default the actual GoZ files which are exchanged.
Look at the date/time stamp of the files. The latest ones are probably the ones which cause a problem. Make a backup of the folder and delete the latest ones (most likely in the GoZBrush folder). After that restart Poser. If you delete files in the GoZApps/Poser folder you might need to reconnect to poser again in ZB
Maybe this info puts you on the right track
BlackTalonArts ( ) posted Sun, 06 November 2016 at 12:14 PM
Thanks Wim, Poser is a fresh install so it's weird that it would get confused right off the bat. I'll try some of the things you suggested and see if that works. Appreciate your time. :)
Karth ( ) posted Thu, 05 January 2017 at 1:00 AM
Where can i get this plugin ? I have only Poser zbrush Export in Poser 11..and that will save a file, that i can´t open in Zbrush. I guess it should work like the Goz from DS to Zbrush ?
ironsoul ( ) posted Thu, 05 January 2017 at 12:34 PM
Its included with the Poser Pro version
Karth ( ) posted Thu, 05 January 2017 at 12:43 PM
Ah..found it. After updating it was usable.
