Thu, Nov 14, 2:41 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 14 12:21 pm)
banner
Subject: How to import M4
Flog ( ) posted Fri, 02 December 2016 at 4:42 PM · edited Thu, 14 November 2024 at 2:28 PM
I'm trying to get M4 into Poser 11. It ain't working. I do import Zip file first and then I copied over Runtime but not the same runtime as 11 is now. How do I get Michael over here?
Boni ( ) posted Fri, 02 December 2016 at 5:08 PM · edited Fri, 02 December 2016 at 5:09 PM
If you have M4 already set up in another runtime, just add that runtime to P11. (in library see little library icon with plus sign in upper right side) Point to the file containing the runtime (make sure it has a unique name i.e. the version of Poser it resides in) and M4 should show up. There are other reasons it might not but we can go through that if necessary.
To help us help you. Could you step us through the procedure you used. It would be great to add screenshots of possible.
Boni
BratskieTest ( ) posted Fri, 02 December 2016 at 5:31 PM
open the zip file (If you see a Content or My Library folder, double click on that....) then copy everything you see in the zip file into the runtime you want to use.
when you open Poser 11, you should see M4 in characters > DAZ People.
Flog ( ) posted Fri, 02 December 2016 at 9:59 PM
got it. thanks.
