Sun, Jan 26, 10:39 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Emission
Robo2010 ( ) posted Mon, 05 December 2016 at 9:12 AM · edited Sun, 26 January 2025 at 1:46 AM
Anyone who played in Blender knows what this is. Emission a NOD that can be used as lighting instead of using lights. In Poser (11) I found this surprise. I tried it, and unable to get it to function. I get poser crashes, and/or doesn't do the job (lighting). Anyone ever tried Emission in Poser?
Robo2010 ( ) posted Mon, 05 December 2016 at 10:33 AM · edited Mon, 05 December 2016 at 10:33 AM
Emission used in Blender. No lights.
jura11 ( ) posted Mon, 05 December 2016 at 5:00 PM
Hi there
This Emission node works in Poser 11,I'm using this node most of the time no just for car lights but for interior lighting too,please have look on my attached pictures
Here is quick 30 samples render
And here is simple Emission node
Hope this helps
Thanks,Jura
Robo2010 ( ) posted Tue, 06 December 2016 at 2:19 AM
Ok. That is wow!!. Not seeing the emission nod (being used). Have trouble seeing material settings. Unable to enlarge.
Robo2010 ( ) posted Tue, 06 December 2016 at 2:33 AM
In image shows that using a flat plane for lighting. Will delete lights when all ready to render. But need to make it an "Emission" for lighting. So going into material room, I see "Emission" node. When connected, it goes black. Unable to light up, or set material properly. Do not know what I am doing wrong.
Robo2010 ( ) posted Tue, 06 December 2016 at 2:51 AM
Blender using Emission node to light up scene.
keppel ( ) posted Tue, 06 December 2016 at 6:10 AM
Online Now!
If your familiar with Blenders node tree setup then you can do the same thing in Poser 11, literally re-creating it node for node. If you go to the material room and select the Advanced tab, right click then select: New node>Root>CyclesSurface This creates a node called CyclesSurface which is the Poser equivalent of the Material Output in Blender. Click the Superfly check box and then start adding nodes from the Cycles collection just as you would in Blender. Emission.png
My Renderosity Store
Virtual Furnishing
My Portfolio
Robo2010 ( ) posted Tue, 06 December 2016 at 7:42 AM
Well look at that? Gotta try. Thanks.
Robo2010 ( ) posted Tue, 06 December 2016 at 8:06 AM
And it does. Will do wonders in Poser. 😃
wscottart ( ) posted Mon, 09 January 2017 at 9:54 PM
Finding this to very very helpful. Thank you all for this wonderful thread.
