Mon, Nov 25, 11:25 AM CST
Subject: Poser Pro 2014 Victoria 4.2 Elite Body Shapes
Inspired_Art ( ) posted Wed, 07 December 2016 at 4:02 PM · edited Mon, 25 November 2024 at 8:51 AM
I hope someone can solve my problem. I am trying to apply the elite body shapes to Victoria 4.2, but when I go to spin the Morphs++ Fantasia dial, only the head is affected. Any clues?Capture.PNG
Eddy
ironsoul ( ) posted Wed, 07 December 2016 at 4:38 PM
Your screen shot doesn't match what I have, FantasiaBody is under the "Morphs|Shapes" section in my menu and the dial shown above as FantasiaBody is "HeadSize".
Nails60 ( ) posted Wed, 07 December 2016 at 5:08 PM · edited Wed, 07 December 2016 at 5:09 PM
There seem to have been a lot of these queries lately concerning V4/M4 morphs. They all boil down to the morph sets need initialising. So if you look at one of these threads this should help. For what its worth I never managed to sort this out using the batch file, instead I downloaded and installed V4 and the morphs using the DAZ installer which automatically sets them up.
Inspired_Art ( ) posted Wed, 07 December 2016 at 5:14 PM
Yeah, this is crazy. I loaded V4 without any morphs, then applied the INJ Elite V4 under the Morph Injections and all it ended up giving me is the GenitalCrease2 dial.Crease.PNG
Eddy
Inspired_Art ( ) posted Wed, 07 December 2016 at 8:16 PM
Nails60 posted at 8:10PM Wed, 07 December 2016 - #4292132
Unfortunately that's correct now. Before DAZ3D came up with the download manager, which is not that bad of an idea.. the batch file worked automatically right after the installation was done. But now nothing works quite right unless handled by the DM. The only problem I seem to be having with it is that if you aren't aware of certain things...like it will download everything to one central DAZ location, unless you somehow learn to tweak the settings.
Anyways, I tweaked, downloaded all the V4 files I needed, including the Elite Shapes, and installed just those files. Located the install directory and moved the runtime into the main PP2014 directory. Everything works now.
Eddy
stallion ( ) posted Wed, 07 December 2016 at 10:47 PM
you will need to inject the HeadSize morphs from Morphs++ then you will have the option in your libraryScreenshot2.PNG
You might as well PAY attention, because you can't afford FREE speech
ssgbryan ( ) posted Sat, 10 December 2016 at 5:06 PM
Nails60 posted at 3:59PM Sat, 10 December 2016 - #4292132
These queries may be coming up because in Poser Pro 11 - the initialization can randomly go haywire. The dials are there & we can spin them, but the model doesn't respond.
I haven't submitted a bug report yet because I can't figure out what is causing it. They will be working, and then all of a sudden they won't. I ended up deleting all of the ones that I had created (M4/V4 with all associated morphs and correction packages) over the years and am starting over.
The ones I have recreated in Poser Pro 11 seem to be working - although now I am having a problem with the Libraries window - it will stop responding to mouse clicks - but I can still drag the pose or whatever onto a base figure and the pose/cloth/whatever will load right up.
