Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 12:41 am)
It's a method of applying texture maps to bodyparts separately using a Pose file Hack similar to MATpose files. The best way to learn how to create one is to purchase the set DAZ brokers for Anton and have a look inside. It does kind of make a mess out of the CR2 when applied, but it works well enough. -JH.
It is hard to clean up if you want to go back to regular materials, I think. Each body part has it's own complete set of material settings, including the ones you don't need, right down to each individual finger segment. I'd really like to see a perfect conforming set of stockings that morph with V2 competently rather then go the route of adding new materials. Also, considering lace is transparent in spots, you may have a clash of skin tone with this technique unless you personally modify the maps. -WTB
no, because the subdividing MAT pose may have changed the "custom material" from 0 to 1 ( or 2, or 3, or ... :) so the original texture is here but in the "channel" 0, so by making a blank subdividing MAT ( pointing to "NO_MAP" for keeping the original maps ) and specifying "custom material 0" to switch back to the original state... in fact, you can make a full body subd MAT pose file in order to clean the whole figure with two clicks :) joelegecko
Just to clarify... If I use a subdivide mat pose I know I cant reapply a texture , but If I make a new subdivide pose file that sets all custom materials back to 0 and apply no map ,this puts it back in order so then I can control things from the material editor again? Looking at the files I notice some of the custom materials are set to different values...not all set to 1 so what do the different numbers specify?
What exactly are subdividing materials and how do you make them? Or better yet, can someone point me to tutorials that explains these concepts Thanks. azl
