Thu, Jan 9, 5:39 PM CST
Subject: How do I...???
Exotica ( ) posted Fri, 12 October 2001 at 10:56 PM ยท edited Thu, 09 January 2025 at 5:36 PM
How do I change the default Poser settings so that when I open Poser it opens with my preferences for window size, tool placement, light set, etc. I know how to change all those things and save as a pz3 but not as the default Poser pz3. Anyone know? Thanks.
Jackson ( ) posted Fri, 12 October 2001 at 11:19 PM
Set the document window up the way you want it then open the Edit menu. At the bottom of that menu, select General Preferences. A dialog box will open. Under Document Preference select the "Launch to Preferred State" radio button. Then click the "Set Preferred State" command button. Click OK.
Exotica ( ) posted Fri, 12 October 2001 at 11:24 PM
Thanks Jackson. I thought that's how it was done but when I try to save it I get an error message that it can not write to disk. Any idea what that's about?
Jackson ( ) posted Sat, 13 October 2001 at 5:49 AM
No, not a clue. But it doesn't sound good. I'd contact CL's tech support on that one.
spothmann ( ) posted Sat, 13 October 2001 at 8:36 AM
...at the files in your poser installation folder? Maybe some of them are set to "write protected" (you can look this up in the explorer by right clicking on each file). Just remove the wirting protection, and try again. HTH, Sabine
chriscox ( ) posted Sat, 13 October 2001 at 8:36 AM
If your using Window you may want an check and make sure that the file Runtime/prefs/preferredState.pz3 is not read only. Chris Cox
Chris Cox
spothmann ( ) posted Sat, 13 October 2001 at 8:41 AM
...that was exactly what I was trying to say, but my english is not good enough, as I am a native geran speaker :-) Sincerely, Sabine
Exotica ( ) posted Sat, 13 October 2001 at 9:43 AM
Yeh! Thanks all. That was it Chris. Thanks much! Pam
