Sat, Jan 25, 3:02 AM CST
Subject: spawning morphs from the magnets, in one go?
MistyLaraCarrara ( ) posted Fri, 10 February 2017 at 8:49 AM · edited Thu, 23 January 2025 at 3:08 AM
i remember doing it for the Morphing Clothes utility, but i don't remember now.
something in poser was able to spawn all the magnets in one go.
could someone please tell me how to do it again?
thanks 😅
pikesPit ( ) posted Tue, 14 February 2017 at 2:05 PM
First, reset ALL other morphs of the figure to zero. Otherwise they will be included in the new morph, which probably isn't what you want... So it's good advise that whenever you work with magnets, always work on the base figure with no morphs at all!
Then go to "Poser Menu -> Object -> Spawn new morph Target" and give the morph a distinctive name. COPY the name in case the morph spans more than a single body part, because you must repeat the procedure with every body part involved. You just have to hit [CTRL]-V to paste the exact same morph name in every body part morph target spawned: "Acoids" typos 😀 !
I just wish SM would finally add an option to work with magnets on a morphed mesh and save a morph created with magnets just like they do in the Morph Tool: ONLY the vertices moved by the magnet, WITHOUT all the other morphs possibly applied!
I mean: It works exactly this way in the Morph Tool - why the Dickens not on magnets??
hth...
Peter
bwldrd ( ) posted Tue, 14 February 2017 at 4:43 PM
Try Spawn Full Body Morph under the Figure Menu.
Consider me insane if you wish, but is your reality any better?
MistyLaraCarrara ( ) posted Wed, 15 February 2017 at 7:55 AM
Thanks!
Miki3 has a lotttta deformers.
tonyvilters ( ) posted Thu, 16 February 2017 at 2:30 PM
Hi MLP. Before spawning morphs from magnets be sure that they are symmetrical left-right.
A lot of Posers newer functions depend on symmetry.
Older figures like Alyson, Sydney, and Miki4 had around 42 symmetry errors in their magnets.
So, please check left-right symmetry for the magnets, dependencies, zones before spawning FBM. Best regards, Tony
