I can take a cube, for example, and using a high res square drape it over the cube. But if I import an OBJ figure and take this the hi res primitive square, I cannot set up the collide information. When I click on add/remove and select figure and ground and click OK. Nothing happens and the box for the object to collide with still says none. Any ideas? I assume all is set up correctly because the high res primitive square will drape over the cube. Thanks. I am getting very frustrated. I normally work in DAZ, but the cloth room is easier, theoretically, than the dynamic module for DAZ which I can't seem to get to work either. I want to make sheets to cover parts of figures.
