Tue, Jan 21, 5:12 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: video tutorial on converting to blended weights
MistyLaraCarrara ( ) posted Fri, 31 March 2017 at 5:28 PM · edited Mon, 20 January 2025 at 10:32 PM
this on utoob! 💗💕
MistyLaraCarrara ( ) posted Fri, 31 March 2017 at 5:29 PM
Thank You very much Wendy 🌸
diomede ( ) posted Fri, 31 March 2017 at 5:59 PM
Thank you, Wendy.
Antaran ( ) posted Fri, 31 March 2017 at 7:36 PM
Thank you! That really helped me finally get an idea of what it would take to make the figures work in Carrara!
WendyLuvsCatz ( ) posted Sat, 01 April 2017 at 3:47 AM
YW
I am just glad Misty made her characters
The Blended weight conversion does not stop the original Genesis 3 figures crashing Carrara BTW, Misty fixed the stuff that did that
and I suspect that's why a few odd outfits still do too.
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
MistyLaraCarrara ( ) posted Sat, 01 April 2017 at 8:41 PM · edited Sat, 01 April 2017 at 8:43 PM
Hiya 👋
About the Folders
genesis 3 carrara should be in a subfolder under 'content', or in some cases it migt be called 'my library' carrara needs to be able to find the ds 'data' folder
when you add the content folder to carrara, select the folder with the data folder directly below it. the daz3d folder is 1 too high
. cheers
galaxiefilm ( ) posted Mon, 03 April 2017 at 2:18 PM
Thank you, very much!
diomede ( ) posted Sun, 30 April 2017 at 9:43 AM
I've had a lot of success converting clothing using the blend function. Thanks for the tute.
diomede ( ) posted Sun, 30 April 2017 at 4:59 PM
For the outfits that still crash - do they crash on load, or crash on conforming. Either way, consider bringing them in as obj and then use VWD.
MistyLaraCarrara ( ) posted Mon, 01 May 2017 at 9:38 AM
the winter dress that crashes, crashes on load
diomede ( ) posted Mon, 01 May 2017 at 4:54 PM
Winter dress. Hmmm. I wonder of the fur lining is causing the crash? Might check out the obj. Can the obj be loaded in Hexagon? Is he fur lining funky?
MistyLaraCarrara ( ) posted Tue, 02 May 2017 at 9:37 AM
there's a winter dress version for g2f. could try autofit to use on g3. been so busy converting the g3 clothes to blended, haven't started testing what g2/gn/v4/m4 stuff autofits nicely.
wonder how well the wear them all works 👗 and the decrackifier
MistyLaraCarrara ( ) posted Sat, 19 August 2017 at 11:50 AM
other than the "smart" tab, what does the ds cms do for carrara?
does it do anything for autofit in carrara?
enquiring minds want to know lol
