Fri, Nov 22, 5:18 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: Failed to load URL http://127.0.0.1:11530/nonVirtualAssets/ContentLibrary/r
Hydra ( ) posted Wed, 03 May 2017 at 10:39 PM · edited Fri, 22 November 2024 at 5:02 PM
What is this and why is it there instead of my library? Nevermind, how do I un-screwup this issue? Here is the entire error that appears in my library window instead of the library: Failed to load URL http://127.0.0.1:11530/nonVirtualAssets/ContentLibrary/release-1.9.1/ContentLibrary/ContentLibrary.html with error (-118)
Thanks.
Hydra
seachnasaigh ( ) posted Thu, 04 May 2017 at 9:01 AM
If you're using the internal library, check your firewall and make sure Poser (and Queue Manager) have "internet" permissions. What they actually use is only internal LAN connectivity; i.e., the library and Poser (and Queue Manager) are separate executables, so they require firewall permission to be able to communicate with each other.
LaurieA ( ) posted Fri, 05 May 2017 at 11:56 AM
diogenese posted what may be the solution to your problem in your other thread here: https://www.renderosity.com/mod/forumpro/?thread_id=2912859
ockham ( ) posted Fri, 05 May 2017 at 4:56 PM
I've found that this message appears and disappears for no obvious reason. At first I tried refreshing the preferences, which seemed to help; but then I noticed that the message generally goes away the next time I use Poser anyway. It's guaranteed to appear when I try to open Poser immediately after closing. Perhaps Poser's background stuff is still busy cleaning up the previous session.
My python page
My ShareCG freebies
