Thu, Feb 13, 12:13 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Problems Installing PICK Content
cmaka99 ( ) posted Sat, 06 May 2017 at 10:09 PM · edited Wed, 12 February 2025 at 11:54 PM
I purchased Poser 11 with the PICK Ultimate Bundle and the Poser Content Super Bundle. I had originally tried to install the content on my (vastly larger) D drive, but could never get that to work. Life and other things got in the way, and I'm just now getting back to this. I decided to quit swimming against the current and just do what the PICK instructions say to do to insall, which is: "To install the product, extract the Runtime folder included within this .zip into your Poser root directory. When prompted, choose overwrite."
I've done that, but no sign of the PICK content. In the PICK manual it says that I should find assets under Poser library: Props > PICK > Base, but there's no PICK category under Props.
This is kind of driving me crazy. What am I missing?
--Chris M.
Nails60 ( ) posted Sun, 07 May 2017 at 8:38 AM
Which poser root directory did you unzip to? When you install poser two runtimes are created, if following the defaults one will be in you programs folder and the other in your public documents folder. All content should be added to the folder in the public documents. BUT Rather than load new content into the poser you are better off creating new runtimes, in future if you want to upgrade poser you don't want to have the default content duplicated. Create a folder ANYNAME and in this create a folder "runtime" Make sure it is a public folder that poser can write to. Now use the add library function (top right corner of the library pane), this opens an explorer window, navigate to the runtime folder you have created and click ok, a library ANYNAME should now be added. If you get an error message it is probably because poser can't write to this folder so check the folder properties to allow poser to write to it. You should now be able to load content to this folder, either by using the install from zip in poser's file menu is the content is properly packaged or by manually unzipping.
cmaka99 ( ) posted Tue, 09 May 2017 at 12:05 AM
Thanks! I think I somehow screwed things up with my initial custom install. I uninstalled Poser and reinstalled using all the defaults. I then made the second folder with its own runtime and have been able to install and access everything.
