Mon, Jan 20, 9:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Object doesn't accept Image_Map well.
ElZagna ( ) posted Wed, 21 June 2017 at 3:44 PM · edited Sat, 11 January 2025 at 9:58 AM
I have this bed called "Jahrhundertstahl Eisenbett". It was a freebie from long ago, and apparently it was quite popular. When I try to apply an image_map node to the bed_linen part it, well, misbehaves. Here it is in Preview. The checkered pattern is NOT the image_map.
And here it is rendered:
Again, the strange pattern is NOT the image_map.
So, what's going on here, and can it be fixed?
OS: Windows 10 64-bit, Poser: 10
ironsoul ( ) posted Wed, 21 June 2017 at 4:36 PM · edited Wed, 21 June 2017 at 4:49 PM
Could there be a second duplicate object there? If so applying a small displacement to the material might help. The other thought is if your using normals the mapping is wrong. Providing a screen shot of the material will help.
Boni ( ) posted Wed, 21 June 2017 at 5:58 PM
As Ironsoul said, if you can give us a screenshot of the Mat room advanced settings we can better help you. Also, which version of Poser are you using?
Boni
rokket ( ) posted Thu, 22 June 2017 at 7:11 AM
It looks like it's not UV mapped properly, if at all...
SamTherapy ( ) posted Thu, 22 June 2017 at 2:51 PM
rokket posted at 8:50PM Thu, 22 June 2017 - #4308194
My thoughts exactly.
EnglishBob ( ) posted Fri, 23 June 2017 at 4:13 AM · edited Fri, 23 June 2017 at 4:14 AM
It is the UV mapping. This is the 8_-_Bedlinen material in UVMapper Pro:
All the materials need remapping, as far as I can see; the bed was originally modelled from primitives, going by the group names.
No offence to the creator, because this is freestuff and of course we appreciate it as such: but last time I loaded this into a scene, my reaction was to replace it with something else. Yes, it could have been fixed, given time, but there are plenty of other beds out there.
ironsoul ( ) posted Sat, 24 June 2017 at 1:24 AM · edited Sat, 24 June 2017 at 1:25 AM
I was expecting the cause not to be UV related as the preview worked. Is it known why OpenGL did not have the problem? Curious as sometimes when working on a new mesh I just use preview mode.
EnglishBob ( ) posted Sat, 24 June 2017 at 9:44 AM
The OP said 'The checkered pattern is NOT the image_map' - although we don't know what the texture was, I assume the preview was messed up too.
The bed loads with procedural materials on it, so that would be the easiest way to make use of it.
rokket ( ) posted Sat, 24 June 2017 at 3:29 PM
I suspect that since it was made from a primitive it was UV mapped, and whatever the creator did to it messed the mapping up.
ElZagna ( ) posted Tue, 04 July 2017 at 5:11 PM
I apologize for not being more attentive to this thread that I started. I guess I'm not being notified when someone responds. Everybody's been trying to be helpful and I've been AWOL. I think EnglishBob has it figured out. It's a nice bed but not worth the trouble.
EnglishBob ( ) posted Wed, 05 July 2017 at 6:01 AM
No problem. I'm not getting notifications any more either, even though I'm still shown as subscribed to the thread. It's been a known problem on this forum for a couple of years at least. I leave it as an exercise for the reader to predict when it's going to get fixed.
I think the bed was designed to use procedural materials, hence the lack of useful UV mapping. It works fine with materials that don't use UV coordinates.
