Sat, Feb 1, 12:43 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:20 pm)
Subject: Pin Up Lingerie by nikisatez
Zatanna ( ) posted Tue, 25 July 2017 at 2:33 PM · edited Tue, 14 January 2025 at 9:24 AM
I'm having trouble making this fit. I've reloaded it several times, looked over the "read me", loaded the pose to the figure and to the clothes, but nothing works. A little help, please?
Boni ( ) posted Tue, 25 July 2017 at 2:50 PM
I'm not sure what the problem is. If you could show some screen shots that would help ... and you could site mail the vendor as well.
Boni
Zatanna ( ) posted Tue, 25 July 2017 at 3:20 PM
Tried fiddling with it some more with no results. Here's the pictures. On the left are the clothes parented to the figure. On the right is the figure with the morphs. As you can see, there is no change. I've included the scale that appears with the morphs, but it does nothing.Untitled.jpg
EClark1894 ( ) posted Tue, 25 July 2017 at 3:32 PM
What program and version are you using?
Boni ( ) posted Tue, 25 July 2017 at 3:43 PM
Based on the version of Poser you are using there are several solutions to this issue. So as EClark1894 stated, we need to know what version of Poser you are using.
Boni
Kalypso ( ) posted Tue, 25 July 2017 at 3:49 PM · edited Tue, 25 July 2017 at 3:53 PM
Site Admin
You have to inject the V4 ++ Morphs first and then use the Inj pose included in the product ONLY on V4 not the clothes. Then load the clothes and conform them to V4. V4.2 Morphs ++
seachnasaigh ( ) posted Tue, 25 July 2017 at 4:16 PM · edited Tue, 25 July 2017 at 4:17 PM
To emphasise: conform the clothes to V4, rather than parent the clothes to V4. Then pose the doll; do not pose the clothes. If conformed, the clothes should follow the doll's pose automatically.
Zatanna ( ) posted Tue, 25 July 2017 at 5:43 PM · edited Tue, 25 July 2017 at 5:54 PM
I meant "conform" rather than "parent". I have loaded the body morphs before the clothing morph, but it never made any changes in the figure. I'm using Poser 9.
I just tried it again. I re-loaded the figure, the morphs, and clothes. I removed the body morphs and re-loaded them. Nothing works.
Kalypso ( ) posted Tue, 25 July 2017 at 6:59 PM
Site Admin
The morphs will not load from the injection pose in the product. You will need to load the morphs++. Do you have these morphs? I gave you a link above. If you don't have the morphs then the product will not work correctly. It should have been noted that the V4.2 morphs ++ is a required product.
JAFO ( ) posted Tue, 25 July 2017 at 8:18 PM
Try this:Image1.jpg
Y'all have a great day.
Kalypso ( ) posted Wed, 26 July 2017 at 1:35 AM
Site Admin
From what I see in the picture V4 is not morphed. The injection pose in the product files does NOT inject the morphs ( I have the product and checked it and opened it up in a text editor), it only sets the values. The OP needs to have V4.2 Morphs ++ installed and injected into V4 FIRST and then apply the injection pose the vendor has supplied and finally load and conform the clothing. It's not rocket science people :) I've already given a link to the Morphs++ that the OP can buy at DAZ if they don't have them.
hborre ( ) posted Wed, 26 July 2017 at 10:11 AM
And considering that the model is V4, you may need to apply the clothing magnets as well for a better fit.
Zatanna ( ) posted Wed, 26 July 2017 at 11:17 AM
Did that. Did that. Did that. I can't understand the problem. I'm going to download EVERYTHNG, delete EVERYTHING, reload and try again. If it still won't work, I'll contact the seller.
Than you for all your help.
ypvs ( ) posted Wed, 26 July 2017 at 7:03 PM
Have you had the V4.2++ morphs long? Do they work if you apply and set an individual FBM such as Voluptuous or BodyBuilder or with characters? Could be you need to initialise them with DZCreateEXPFiles-V4.bat in :Runtime:libraries:!DAZ! folder
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Zatanna ( ) posted Fri, 28 July 2017 at 11:39 AM
Wonder of wonders, it worked! Thank you, ypvs and everyone else who answered.
