Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
You can delete content the same way you delete any file. In your libraries there is a "-" symbol ... highlight the file you want to delete and viola. Or you can do this through your OS file system as well. Be careful not to delete essential items ... not sure what they would be, but I'd still be careful.
Boni
Boni posted at 6:46AM Tue, 05 December 2017 - #4319382
thanks boni, where do i find the libraries?
It's just your library system that you pick your figure/pose/hair ...etc. from. How experienced are you with Poser? I can help ... but I won't be back till later this morning. The library icon on the top right of your UI will open the library and we can go from there. Take care.
Boni
Boni posted at 6:55AM Tue, 05 December 2017 - #4319388
thanks boni, i am pretty new to poser, and i dont use it a lot, but i found the files!!
thanks for your help, and greetings, robozo
The only downside to deleting the Poser content is finding all the associated textures, poses, materials, etc which will take up unnecessary space on your hard drive. And as Boni mentioned, be very careful about essential scripts, you can very easily break Poser by deleting the wrong files or file types.
hborre posted at 10:24AM Tue, 05 December 2017 - #4319411
ok thanks a lot! ill give it a try, if anything breaks, ill just re-install poser!
thanks and greetings, robozo
hi all
i want to delete some of the standard (not downloaded) content that comes with poser11, because i dont need it. is that possible?
greetings, robozo
