Fri, Nov 22, 4:59 PM CST
Subject: Tiling
cainbrogan ( ) posted Sat, 13 October 2001 at 3:44 PM ยท edited Wed, 13 November 2024 at 9:39 PM
How do I tile a symetrical lattice that is say 5x5x5? I think thats what I mean, the boolean primitive yoiu create to edit and form rock structures. = )
douglaslamoureaux ( ) posted Sun, 14 October 2001 at 12:32 AM
Are you trying to create multiple copies of the object, one after another, in a row, or are you trying to make a series of objects of iregular shape that can be placed next to each other like a stone wall? Both can be probably best done by creating a picture of the planform of the object outside of bryce, using something like photoshop, photopaint or paint shop pro. make a lattice object, click on the E, and then hit the "picture" radio button On the "editiong tools" Menu. This will then let you import the picture. You can obtain the desired shape by setting the null area to black. Click on the square in the upper corner of the terrain canvas to make a slider visible on the right side. Move the bottom of the slider up to remove the black areas from the shape of the lattice. I hope I understood your question, and I hope this helps!
hogwardenwork ( ) posted Mon, 15 October 2001 at 8:42 AM
I think you might be talking about tiling terrains! You can do this using the TILE NORTH, SOUTH, EAST and WEST buttons in the drop-down list in the terrain editor. This allows you to create terrains which glue perfectly together at the edges... a continuation of the same fractal. This is too complex for me to explain without Bryce in front of me, so I suggest you look for a tutorial called "Tiling Terrains" or "Tiled Terrains" which clearly explains how to use this function... Good luck!
cainbrogan ( ) posted Mon, 15 October 2001 at 12:38 PM
hogwardenwork, That is exatly what I'm refering to,thanks . Will this work infinetly? I'm not home now, can this be done with B3? = )
cainbrogan ( ) posted Mon, 15 October 2001 at 12:39 PM
cainbrogan ( ) posted Sun, 21 October 2001 at 2:19 PM
hogwardenwork, I've tired the Tile North, S, E and W with B3, but i ca'nt find that function. Would you reply with a screenshot of where this command is located? Thanks Ahead of Time!, Cain Brogan = )
Bladesmith ( ) posted Fri, 26 October 2001 at 6:34 PM
I don't believe B3 had the fractal terrains B4 has.
cainbrogan ( ) posted Sat, 27 October 2001 at 2:03 PM
B4 has...Would we need B5? }= )
