Fri, Jan 24, 1:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 12:37 pm)
Subject: M4 VS GENESIS
calmday ( ) posted Sun, 14 January 2018 at 1:22 AM · edited Fri, 22 November 2024 at 6:49 AM
I have another thread on the endless problems I am having with M4. Basically because its dependent on FICKLE morphs which I have never gotten to work.
SHOULD I MOVE TO GENESIS {1} and DYSON instead? is that an easier system? Can M4 products { clothes, hair} work with that easier == in poser ? Does it still need morphs?
thanks
lonelybat1989 ( ) posted Sun, 14 January 2018 at 5:50 AM
What morphs are you having problems with? Whats not working? I haven't had any issues with M4 what so ever, except for the FREAK morph, but thats easily fixable. Let us know whats going on, and I'm sure someone here can help.
KarinaKiev ( ) posted Sun, 14 January 2018 at 1:36 PM · edited Sun, 14 January 2018 at 1:38 PM
First of all, take a DEEP BREATH and calm down...
Opening new threads and jumping to new ideas in each one will only scatter the topic and the support you get will trickle at random bits.
One bit here: If you can't properly install M4 in your runtime, I doubt that you will be able to get Genesis and the "DSON" (not Dyson - that was an astronomist) to work properly!
If your Volkswagon doesn't start it's not a good idea to install a Ford engine and hope that all will be well then... Oh, and don't ask the FIAT people either! :)
Best idea would be to continue this HERE:
https://www.renderosity.com/mod/forumpro/?thread_id=2920839 and then HERE:
https://www.renderosity.com/mod/forumpro/?thread_id=2920835
Then we have ONE thread where we can try to help you, instead of several scattered ones. Thank you.
Karina
Kazam561 ( ) posted Sun, 14 January 2018 at 7:02 PM
On a side note, if you are having troubles with bends, there are both these products. Be advised these are for M4. The clothes would need some adjusting using the morph brush in poser.
https://www.renderosity.com/mod/bcs/perfect-booty-m4---automatic-fix/92326/
https://www.renderosity.com/mod/bcs/simpledetailsm4/77763/
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
