Sun, Nov 17, 1:29 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Issues with importing a mesh with the weld identical vertices option on.
FVerbaas ( ) posted Thu, 04 January 2018 at 4:20 PM · edited Sun, 17 November 2024 at 11:27 AM
Forum Coordinator
I ran into na issue with importing a mesh with the option:
imoptions[poser.kImOptCodeWELDIDENTICALVERTS] = 1
despite this.the imported mesh is not welded.
I reported to Poser team and they replied they suspect it might be a problem on Poser python support that is ignoring the weld option. If this is the case they want to solve it in the next maintenance release.
So just in case you run into similar issues, it may not be you who is in error.
FVerbaas ( ) posted Mon, 15 January 2018 at 11:37 AM
Forum Coordinator
I was advised today a fix is in the works ...
