Tue, Jan 14, 9:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: Help pasting images onto figures
crystalmethodcaf ( ) posted Mon, 26 February 2018 at 11:25 AM ยท edited Tue, 14 January 2025 at 12:17 PM
Hey! Hope this is the right place to ask for help with this. I've been making lots of wrestling art, and it'd add so much more to it if I could really paste images onto objects, but I can't seem to figure it out! For example:
  • On a titantron, pasting a picture that'd show on the whole titan tron
  • Pasting a picture onto ring apron
  • Pasting a flag onto a top
  • Pasting a picture on the mat
I can't seem to find out how to do this! I go to the materials, then load the texture for the part as the picture I want to use, but it just displays a tiny segment of it and it's all distorted. I played with the advanced settings but couldn't get it to work right.
Any help?
hborre ( ) posted Mon, 26 February 2018 at 3:16 PM
You need to have knowledge of the UV arrangement used with the content was made. Without it, any image you try to place in Poser's Material Room will either show up the wrong size or distorted because of misplacement on the mesh. Check if the vendor provided a UV template for all the content in his/her product, usually it will be a .jpg image which can easily be opened in Photoshop or GIMP. Open the template in your 2D software, then add your custom image to another layer. Create any additional masks based on the same template and save the necessary images. When you return to Poser, you can add the newly created patchwork to your content. Again, this is only possible if UV templates exists. Otherwise, having to create UVs from scratch is a rather long, complicated method involving UV Mapping software and a bit of experience.
crystalmethodcaf ( ) posted Tue, 27 February 2018 at 11:51 AM
Well that's a whole lot more than i'd hoped for... The method I explained worked for the pre-loaded Poser 7 The Pad TV screen, was hoping it was that simple for other stuff too... oh well, I appreciate it!
SamTherapy ( ) posted Tue, 27 February 2018 at 2:34 PM
It will work for a TV screen, since most of 'em are mapped to accept a flat image on the screen part. Other stuff may not be.
