Wed, Feb 12, 10:05 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Feb 12 2:40 am)
Subject: MORE rotation issues (seriously?)
the_lova_skul ( ) posted Mon, 26 March 2018 at 9:59 PM · edited Wed, 12 February 2025 at 10:05 AM
the figure "Andy2" SPECIFICALLY has this problem it rotates like a pendulum rather than normally, it'll be in a COMPLETELY different spot once rotated even SLIGHTLY I've tried messing around in the joint editor but it didn't help
before rotation: 2018-03-26.png
after rotation: fdou.pngfdou.png
Nails60 ( ) posted Tue, 27 March 2018 at 5:47 AM
Have you, or has the pose you applied, translated the hip? If you move the figure by moving the hip, the centre of rotation doesn't move with the figure. As an experiment, load Andy and move him by selecting the body, then rotate and you will see he rotates about a point that appears to me to be somewhere between his feet. Now move him back to his original position, turn off ik, select the hip and move this. Now select the body and try rotating him, and you will see the difference.
the_lova_skul ( ) posted Tue, 27 March 2018 at 9:02 AM
bwldrd ( ) posted Sat, 31 March 2018 at 4:45 PM · edited Sat, 31 March 2018 at 4:48 PM
Just what are you trying to accomplish. I'm adding a quickie animation of andy spiraling down the cylinder, if you need to know how it was accomplished let me know.Andy Animation.gif
... Lol, well that was supposed to be a 30 frame GIF, I guess those aren't supported, anyhow.. Andy is at top on frame 1 and bottom on 30. The image is showing the whole transition instead of frame by frame.
Consider me insane if you wish, but is your reality any better?
the_lova_skul ( ) posted Sat, 31 March 2018 at 5:16 PM · edited Sat, 31 March 2018 at 5:17 PM
my goals have changed since i posted this my CURRENT goal is: i want to know how to get andy (or any other character) to interpolate properly, like for example say i make 4 key frames where he's on a different side of the pole, and instead of smoothly rotating like yours, he detaches from the pole spins around than reattaches on the other side, HOW DO YOU MAKE ANYTHING SMOOTHLY TRANSLATE!?!?!
bwldrd ( ) posted Sat, 31 March 2018 at 6:02 PM
Sorry, I don't really animate that much so beyond simple is above my skills. Lol.
Have you tried the spline editor, or the interpolation choser on the keyframe editor?
Also you may want to post in the regular poser forum as I think some of the animators post there. (Don't hold me to this as I'm not sure)
the_lova_skul ( ) posted Sat, 31 March 2018 at 9:15 PM
bwldrd ( ) posted Sat, 31 March 2018 at 9:51 PM
Yep, those. And I mean the poser forum down under the "Software" category of the forums listing. It was the original/regular forum.
