Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
thanks all.
anyway, this is what i ended up doing, inserted oval(circle) to use as a guide, inserted a grid on top of it. moved the outer verts of the grid to line up with the oval verts.
whole bottle still ended up with high poly count, like 800
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Here is another method as per Vyusur which might perform better under smoothing. Rather than start with a square, you can also start with an oval or a cylinder. Here I start with a cylinder with 12 points on loop. Extrude in once to brace the edge loop. Then use Tessalate and join vertexes to center. This yield triangles. No problem. Select two triangles at a time and dissolve (backspace). Now the end of the cylinder is made of quads but the edge loop is braced by an circle. Repeat for other end if closing bottle, or delete other end if bottle is open. Select edge loops of cylinder and shape as desired for bottle length and width.
thanks diomede
your method lowers the polycount
i'm finding when i detach polys, haz to deselect and reselect the polys to move
needing some emotional support with this project.
bar nistress at mistykal selling saurian brandy 'under the counter'
