Fri, Jan 10, 9:37 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 10 10:30 am)
Subject: Problems installing Mx-25 Space Fighter by sevein
Bendinggrass ( ) posted Sat, 19 May 2018 at 5:46 PM · edited Fri, 10 January 2025 at 6:55 PM
I unzipped this and then moved it to a separate runtime. When I asked PP11 to recognize this new runtime it told me it was not a runtime and so did not recognize it. I know from unzipping it, this item does not have a runtime, it is an obj file. So..... where do I put it to be recognized by PP11. I want to use a separate unique folder. Where do obj files go in PP11. Can someone help in this please.....
Nails60 ( ) posted Sat, 19 May 2018 at 6:23 PM
You need to import this rather than install it. unzip the the file to wherever you wish. From the file menu select import wavefront obj then navigate to the the obj file. This should now import the model and you can now save it as a prop to any library you have. I'm afraid I don't have much experience importing objects but if you runinto problems I'm suure if you ask about importing obj files someone will help.
Bendinggrass ( ) posted Sat, 19 May 2018 at 6:26 PM
Thanks Nails60, that is a good start and I will do that.
