Sun, Nov 24, 8:36 PM CST
Subject: PNG export no shadows?
saibabameuk ( ) posted Sat, 26 May 2018 at 3:24 AM · edited Mon, 11 November 2024 at 7:04 PM
Hi Guys the old grey cell not working exporting to Final cut PNG but my figure is not showing a shadow on the ground, I know you have helped before but cannot find the thread. Poser-24:05:18-1.0197.png
saibabameuk ( ) posted Sat, 26 May 2018 at 3:49 AM
saibabameuk ( ) posted Sat, 26 May 2018 at 3:50 AM
Sorted
saibabameuk ( ) posted Sat, 26 May 2018 at 4:26 AM
One small point you see the line around the figure any thoughts about removing it ?
RedPhantom ( ) posted Sat, 26 May 2018 at 6:18 AM
Site Admin Online Now!
Open it in your 2d editor. Use your selection tool to select the figure. Shrink it down by one or 2 pixels. Reverse the selection and erase the edge. If your program has the option, you might also want to anti-alias the selection too.
The outline is caused by part of your background color showing through the anti-aliased edges of the rendered figure. Poser doesn't seem to like making partial transparencies. It adds the background to solidify them.
saibabameuk ( ) posted Sun, 27 May 2018 at 5:07 AM
Thank you Red Phantom Good tip.
SamTherapy ( ) posted Sun, 27 May 2018 at 6:15 AM
The advice from BagginsBill to get rid of the grey lines around a PNG render:
Caveat - this advice is for Firefly and I have no idea if it works in Superfly.
Set render settings to Render Over: Black. Not set your background to black then render over that; specifically use the setting Render Over: Black.
seachnasaigh ( ) posted Mon, 28 May 2018 at 4:52 PM · edited Mon, 28 May 2018 at 4:56 PM
For Superfly, one option is to apply the Cycles holdout node to the entire construct (ground and sky), that gives you a Superfly render of the dolly on a transparent background: Sylfie Superfly raster.png construct material:
RedPhantom ( ) posted Mon, 28 May 2018 at 7:00 PM
Thanks for showing where the node can be found. Sometimes it's like a mystery hunt for them
