Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Sorry not able to check inside poser at the moment. However I wrote a guide on it here.
https://www.renderosity.com/mod/bcs/natural-breasts-for-victoria-4/121981/
If you scroll down its starts just after the second dotted line in the image. The description is obviously for my product, but the way you do it is exactly the same way you just select the morphs you need.
If you have your clothing selected, and the figure you want to copy morphs from is wearing the clothing, you can go up to the top and select "Figure>Copy Morphs From" and then a drop down menu appears where you can select the figure you wish to copy the morphs from. Select that figure then you will have a window appear ( it may take a few moments) where you can select which morphs you want to appear. Select those morphs then hit OK and give it some time and the morphs will be included in the clothing. I hope this helps!
Yes the " Include Morphs, Include scales, Follow origins and the Include Translations" check boxes I think..
Hi,
searching on the net, came across a comment that in Poser Pro 11, there is an option within the program that allows transferring character morphs (such as V4) to her clothing items (in case they might be missing).
I would really appreciate it if someone could point me in the right direction.
Thank you all
vxg139
