Fri, Feb 7, 4:22 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Feb 02 8:19 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: reset coordinate zero
atpo ( ) posted Mon, 06 August 2018 at 7:01 PM · edited Fri, 31 January 2025 at 6:00 PM
Excuse me! When exporting model ,how to correctly reset coordinate zero so that model can be well in other softwares? I often use "Ctrl +A",but I think that there must be something wrong. Thanks.
Lobo3433 ( ) posted Tue, 07 August 2018 at 10:42 AM
Forum Moderator
If I understand this correctly I usually make sure my cursor is at center and then with the object selected (if it is a single object) using the keyboard shortcut "shift S" and choose selection to cursor and that will bring it to center I would also make sure I have applied scale and rotation that usually will export the object out and when imported to another application it will be in the center
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
Miss B ( ) posted Tue, 07 August 2018 at 11:11 AM
In addition to what Lobo said, to make sure your cursor is at the center, click N, and when the toolbar appears on the right, look for 3D Cursor Location, and then make sure the X, Y and Z coordinates all say 0.00000.
_______________
Butterfly Dezignz
Lobo3433 ( ) posted Tue, 07 August 2018 at 2:37 PM
Forum Moderator
Thanks Miss B forgot that one
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
erock3d ( ) posted Tue, 07 August 2018 at 3:16 PM
The first thing you'll want to do is hit "Shift C" which will place the 3D cursor directly in the center of the grid. (Zero position)
Then, as Lobo3433 mentioned, "Shift S" will allow you, with a pop up menu, to Snap the selection (your selected object) to the cursor.
You may need to do a third step though, which is to set, or reset, the origin of your object. If the origin of your object is somehow incorrect, or not exactly where you want it to be, then "Shift S" won't place the object exactly center where you might expect it. For example, with a human figure, you will most likely want the origin point to be at the feet. If the origin were set to the center of the model (its waist area for example) then that is where the "shift S" will snap your model to, resulting in its legs going through the grid floor. Therefore, you may need to use the "shift-alt-center C" key combination to set the correct origin for your model/object. (If the first two things worked though, then the origin of your selected object is probably OK.) Let me know if you have more questions regarding this step, because it can be confusing. It was for me in the beginning at least.
Also, make sure your export and import settings, specifically scale and axis, are correct for the program you plan on exporting to.
Erock3D
atpo ( ) posted Tue, 07 August 2018 at 7:02 PM
Thanks . And Miss B "OK . . . Where's my chocolate?" What about Lobo is your chocolate???
