Thu, Nov 28, 3:35 PM CST
Subject: All apps that can Change UV Map in app keep painting ?
RorrKonn ( ) posted Thu, 13 September 2018 at 6:07 PM · edited Thu, 28 November 2024 at 1:42 PM
In substance painter I map ,paint. then I can auto remap it keeps the paint .So I paint across a closed seem that was not closed on the old map.
Can photoshop do this ? What all other painting app's can do this ?
ironsoul ( ) posted Fri, 14 September 2018 at 1:25 AM
Never thought of doing that in SP, great idea. In Zbrush it is possible to transfer a texture to a different UV set using the copy UV option.
shvrdavid ( ) posted Fri, 14 September 2018 at 12:09 PM
I do that in substance a lot. You can also transfer maps to other figures that way as well. All you have to do is have the obj mapped to both, and off you go.
RorrKonn ( ) posted Fri, 14 September 2018 at 3:50 PM
Thanks for the info so far more is welcomed .
Where getting educated
RorrKonn ( ) posted Wed, 19 September 2018 at 11:33 AM
So I guess substance painter n zBrush are the only app's that can change maps ? I take it Photoshop can't change maps ? No other app's can change maps ?
