Wed, Feb 26, 4:22 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Adding an undo option to a script
ironsoul ( ) posted Sun, 02 September 2018 at 9:31 PM · edited Sat, 08 February 2025 at 8:13 PM
Hi
I have a script that performs multiple changes to a scene and would like to add the ability to rollback if the update fails. I've looked at save/revert but save requires the doc name to be set which could impact a users own save/backup strategy. I'm suspicious of using the undo function as don't know how comprehensive it is. Any thoughts/suggestions would be welcome.
FVerbaas ( ) posted Tue, 18 September 2018 at 3:05 PM · edited Tue, 18 September 2018 at 3:07 PM
Forum Coordinator
It seems you can save with an optional name:
Manual says: SaveDocument Explanation Save an existing Poser document. Takes an optional file name as argument.
Arguments Enter a valid path to save the file to that location/filename. If you do not specify an argument, the file will be saved in its current path with its current name.
Syntax SaveDocument({ filePath})
Example poser.SaveDocument(“C:My DocumentsPoser Stuffmyscene2.pz3”)
ironsoul ( ) posted Fri, 21 September 2018 at 2:58 AM
Thanks FVerbaas. From the point of view of using SaveDocument as a temporary save method it also changes the users current document name which could cause problems if the python script fails during execution. I think the best approach is to use it as an option the user can take prior to the changes.
