Sat, Feb 1, 5:26 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 28 1:01 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: How do you get the mirror modifier copy where you want it
dweomer ( ) posted Wed, 23 January 2019 at 9:58 PM · edited Thu, 30 January 2025 at 3:37 PM
I need help with the mirror modifier. "how" is where I want it to copy to "why" is where it didMirrorModFunky.png
SilentWinter ( ) posted Wed, 23 January 2019 at 11:30 PM
It's mirroring around your object's centre, not the cursor or world centre.
You can remove the modifier, move your object (in edit mode) to the other side of the line, then reapply the modifier. Or else set origin to 3D Cursor (after ensuring cursor is at the place you want to mirror around (like world centre).
If that's not the problem, I'm not sure what is.
Silent Winter's Facebook Page:
Miss B ( ) posted Wed, 23 January 2019 at 11:31 PM
I'm not sure I'm understanding what you're trying to do. You selected a mesh object, used the Mirror modifier, but instead of having it to the right of the original mesh object, which is how the Mirror modifier works, you want it to the left, and unattached? If that's the case, you should "duplicate" the original mesh, not "mirror" it.
Mirroring takes what's on the left side (let's say the top of a jacket" and creates it "mirrored" for use as the right side of the jacket. That way all you need to do is get the two pieces close together so you can weld the verts of the back seam together so it's one "single" piece, not two separate pieces.
Hope that helps some.
_______________
Butterfly Dezignz
dweomer ( ) posted Thu, 24 January 2019 at 12:26 AM
Miss B : Yes that helps a lot. Did not know that left to right was the standard option.
SilentWinter : Setting the origin to cursor did the trick. Thank you.
Miss B ( ) posted Thu, 24 January 2019 at 1:48 PM
Ohhh, looks like SilentWinter and I pretty much cross posted, so I missed the comment about resetting the origin. Glad to see that worked for you. 🙂
_______________
Butterfly Dezignz
