Sat, Feb 15, 11:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 9:24 am)
Subject: New Poser Version
ArtOfDreams ( ) posted Wed, 30 January 2019 at 3:52 AM ยท edited Sat, 15 February 2025 at 7:24 AM
Hello, if I want to install a new version of Poser, do I need to uninstall older versions first?
JohnDoe641 ( ) posted Wed, 30 January 2019 at 4:28 AM
Nope, you can keep as many iterations of Poser installed at the same time as you want. I've done this with PP2012 and PP2014, then PP2014 and PP11 installed and I had no issues.
ArtOfDreams ( ) posted Wed, 30 January 2019 at 4:32 AM
thanks a lot :-)
EClark1894 ( ) posted Wed, 30 January 2019 at 4:50 AM
JohnDoe641 posted at 5:47AM Wed, 30 January 2019 - #4344684
I agree, but just to clarify, you can only run one of each version at a time. I have had 2 different versions running at the same time, but it will affect your computer's operation and speed. So, probably best not to do that. :)
willyb53 ( ) posted Wed, 30 January 2019 at 1:48 PM
Also, if you are running poser 8 with other versions, you must start poser 8 first. All versions after Poser 8 check for available communication channels, poser 8 does not, so if poser 8 is started second it will hijack the default channels.
Bill
KarinaKiev ( ) posted Wed, 30 January 2019 at 5:06 PM
Thanks a lot @willyb53! That explains a lot of the problems I had before when trying my freebies in older Poser versions.
K
3D-Mobster ( ) posted Wed, 30 January 2019 at 8:44 PM
ArtofDream do you work in online marketing?
Because making a post with such a headline is one hell of an amazing click bait on a Poser forum. :D
