I have this problem with Windows 10 as well. Poser seems to work just fine, so I've ignored it. For years. :-)
Some people have fixed it by deleting their preferences file, but that didn't work for me. I got the error on a brand-new, fresh installation on a new computer.
My guess is that some script that loads when Poser is started throws up this error because Poser isn't yet fully initialized when it runs. Some coders deal with this by building in a delay before their scripts start, but it sounds like it's basically a cosmetic issue. Poser and its scripts will work fine once Poser is done loading.
Poser uses xml files to store configuration information.
To see the location of these files
Open python shell -> Scripts->Python Shell
Run the command print poser.PrefsLocation()
If you open in explorer the displayed folder there are a number of files ending xml.
In theory if you right click over each and select your favourite browser to open it, if text is displayed without error the xml file is ok
My guess the problem is with LibraryPrefs.xml which doesn't display ok. You could test this by renaming the file and seeing if the error message dissappears
Why LibraryPrefs.xml doesn't load ok only Smith Micro knows...
It occurs quite often on my MacBook.
