Looking good Pokeydots ;-) The eyebrows are hard to do with Dina because the Two outer layers are so darn thin. I am painting them on too. If you add a bump map to the lips they will highlite themselves. Also in most portrait paintings the upper lip is slightly darker than the bottom one usually.. given the light settings it is normal and expected.
Thanks for the nice comment :) I did add a bump map, so I guess it needs a little more bumping lol. Have you figured out a Curly Santa Beard and Mustache yet ? :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Pokeydots, It's looking very good except that the teeth seem like they're glowing. I can't figure out why. When I look at the face with the teeth hidden, the realistic touches in the texture pop out, and the eye area looks especially good. But wen I uncover the teeth I see only the teeth. Do you maybe have a light ambient color on them? I agree with the eyebrow trans thing. As weird and huge as Vickie's brows look without a transmap, they are much easier to work with. Phoenix
Thanks Phoenix :) I noticed the teeth are bright too, lol I don't know why. On my texture I didn't make them bright like that, so it must be something with the lighting. I'll have to try a close up again.
System Ram: 8GB
pokeydots, I've found putting eyebrows on the texture map and then making transmaps for the two other brows gives them great depth. i've also found making the teeth slightly transparent tones down that too bright look they tend to have. You can also try making the material on the teeth a light, light yellow/gray. On the whole, your texture is looking good. IMHO you might want to tone the green eyeshadow down a bit, though.
DTHUREGRIF, Thanks for the suggestions :) I'm getting a lot of good suggestions, and I appreciate very much :)
System Ram: 8GB
System Ram: 8GB
