Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 21 6:51 am)
Upgrade downloaded and installed and I am currently working on a new image. Runtimes (which I keep on a separate hard drive) installed without problem using the 'add library' button. Just a couple of niggles, one minor, one not so. I prefer to use the navigation buttons on my PC to scroll through the library. No problem with P 11.1 but in P11.2 I reach the bottom of the page at which, apart from jumping a bit, it stops. Annoying but easily overcome by using the scroll bar. Much more aggravating though is the library thumbnails in P11.2. They are minuscule even compared to P11.1 and definitely a drawback for anyone with less than perfect eyesight like myself. Hopefully, this is something which will be addressed sooner rather than later because it detracts from what is an otherwise excellent upgrade!
Hi, donnena! Thank you for your reply. Window's user also here. I was pointed to your solution by a friend on another forum who read my post and I'm delighted to report that everything is sorted. You'd have thought I should have known that after all these years as a Poser user, but I didn't! Cie la vie! Respect!
I upgraded from 11.1 to 11.2.20190812 last night, installing "Install Poser 11.pkg" but not "PoserSupport.pkg". I'm on a MacBook Pro, Mojave 10.14.6.
Purchased items I have in the Downloads folder don't show in the library (the Downloads folder in the library is empty) and I finally had to manually move things I need into the main Runtime folder. The main problem is that navigating the finder from within Poser (adding a library, searching for a missing link when prompted, loading a texture in the material room, etc.) is now ridiculously slow. Click on a folder, wait a minute for it to highlight, then click open and wait another minute, etc., and my tablet immediately stops working and has to be unplugged. Any suggestions would be greatly appreciated.
