There have been threads about this, see one started by Nostrella I believe.
The problem they had was that somehow the file extension had been removed from the file. The file name should be Install poser 11.exe. Try renaming your file to this, or perhaps it was corrupted in downloading so try downloading again.
I didn't manage to find the thread referred to (I could have looked harder) but went ahead and renamed the file and it seems to have worked.
For info, I opened a DOS command window and used the REN (RENAME) command:
REN filename filename.exe
I seem to recall from way back that right-clicking and choosing rename from the pop-up menu in Windows may not rename the filename suffix if there is one. (in this case I needed a suffix of .exe).
Grimhilda posted at 3:11PM Sun, 22 September 2019 - #4363381
If you enable Windows showing you file extensions for all your files, you can directly rename the extensions :)
Feel free to call me Ohki!
I had to go out and now see more contributions. Thanks, Ohki, I didn't want to go searching for a way to do that when I thought I'd get it done in DOS. Sometimes it's nice to look directly at file attributes and so on - even though in my case I often only half-know what I'm doing!
Yes, hborre, I too now have the new version of Poser working but need to complete all the content downloads next.
Thanks and regards to all.
Firstly, given the thread title, thanks for taking a look!
Also, thanks to Bondware, Hivewire, Developers, Beta Testers, helpful Forum members and anyone else bringing a fresh start to Poser.
My problem: I downloaded the Poser install file called Install%20Poser%2011 but when I double-click on it to start the installation it wants me to find an application to run this file with. I'm on Windows 8.5 and have an existing copy of Poser 11 pro from SmithMicro.
I started a new thread because I've seen no-one else with this problem and didn't want to muddle other threads.
Any help would be most welcome.
