Mon, Feb 17, 12:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: Poser Install Problems
lklorio ( ) posted Thu, 03 October 2019 at 6:31 PM · edited Thu, 30 January 2025 at 8:19 AM
Installed Poser Update, Poser couldn't find my Poser content Library or my favorites. Add the Library but don't know how to point the software to my favorites. Any help would be greatly appreciated, Thank You.Favorites.jpg
structure ( ) posted Fri, 04 October 2019 at 8:31 AM · edited Fri, 04 October 2019 at 8:33 AM
Forum Coordinator
Favourites are in :Runtime:Libraries:Collections: in your main poser runtime, if this folder does not exist, or it is empty then you will see no favourites. However, favourites was broken in poser 11 original release. If you add a folder under Collections, you can use that as your base folder to add new content.
Locked Out
willyb53 ( ) posted Fri, 04 October 2019 at 10:30 AM
Online Now!
Hi, You say that you installed the poser update, but did not mention what you updated from. If you updated from PP2014, Your favorites would not come across. Favorites must be in the programs default runtime.
Bill
ThunderStone ( ) posted Fri, 04 October 2019 at 11:14 AM
Thanks for the tip! I was wondering what happened to my collections since I could not write it to the program folder. Glad you posted this.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Boni ( ) posted Fri, 04 October 2019 at 4:46 PM
This fixed it for me ... I hope it did for you as well!
Boni
lklorio ( ) posted Sat, 05 October 2019 at 5:35 AM
Thank you everyone for your input! My favorites were in the collection library folder, poser just refused to see them, probably had a bad day, argument with Posette I think. Anyway, uninstalled everything, deleted all folders even the application data folder. Installed again on one of the secondary hard drives and presto all is well. Really don't know what was wrong, but I know I was doing something wrong even a slap to the side of the monitor didn't work. Thank you again to all and have a great Day!
CuriousGeorge ( ) posted Sat, 05 October 2019 at 3:55 PM
I also found that after the 11.2 upgrade, some of my poser content went missing. Luckily, I had mirrored my poser content onto my other computer. So I copied my mirrored content and placed it on my NAS in a legacy folder and added it to the Poser 11.2 content library. That solved a lot of headaches I was running into.
