Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Have you tried the fix that Snarly made? AVFix
"Dream like you'll live forever. Live like you'll die tomorrow."
ghostman posted at 9:31AM Sun, 06 October 2019 - #4366158
AVFix is only for scripts that are encountering difficulties with the change in Poser's version number format. It won't help with permission issues.
Normally, if you want to run scripts that interact with poserStartup.py you need to run Poser as an administrator or install Poser to a folder not protected by things like UAC.
Free stuff @ https://poser.cobrablade.net/
Snarlygribbly posted at 10:34AM Sun, 06 October 2019 - #4366164
Bummer. Oh well, was a longshot.
Snarlygribbly posted at 7:07AM Sun, 06 October 2019 - #4366164
I wondered if that was it, given where he installed it and the error message. But he apparently had it working before the update, presumably installed in the same place?
Thanks for your ideas. Just to point out people I'm not a newbie to Poser, I have been around since version 3, so I have fair idea of it's workings, Runtime Rodent worked in all versions since it's release back when RDNA was still around, it is only the mentioned update that it hasn't worked with, what I was after is someone to confirm the problem before I took it to Netherworks
I am a bit wary about going to the 3/10 update at least until this issue is resolved one way or another.as it hasn't shown up in Poser as an official update .
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
Rhia474 posted at 6:28AM Tue, 08 October 2019 - #4366237
From the error it looks like it is called from two places (in particular, see the Poser2014 Runtime line on d:). Try to see if you have only one copy, and that it is in the Program Files folder where you have Poser's exe installed?
I'm not sure why that would cause an issue, when it didn't prior to this, also I don't have a D:PoserPro 2014. Also there has never been an issue of running any python scripts in multiple versions of Poser, I have always just copied over the Python directory to the new version and kept them in the previous version, as I always needed a couple of versions for testing.
I have sent a message to Netherworks, so we will see where that leads us.
it alive.
Robert A. Heinlein
Windows 11 Pro
Can someone confirm that Netherworks Runtime Rodent no longer works after update to 11.2.289?
I had it working previous to the official update - here is the error.
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
Windows 11 Pro
