Wed, Feb 19, 2:59 PM CST
Forum Moderators: RedPhantom
Subject: Camera weirdity in 11.2
ockham ( ) posted Tue, 01 October 2019 at 4:34 PM ยท edited Mon, 10 February 2025 at 6:17 PM
I've never had this happen before. The scene is the bog-standard Ockham stuff. Terrain, building, old gadgetry. scene.jpg
When I start with the main camera inside the house and then pull back just a little bit with the 'hand' camera controls, the camera ends up nowhere. Why is it nowhere? The numbers show what's happening.....
All three dolly directions have gone out to infinity-like numbers!
My python page
My ShareCG freebies
SamTherapy ( ) posted Tue, 01 October 2019 at 5:21 PM
That's seriously weird.
You have entered the...
Twilight Zone
dee dee dee dee...
quietrob ( ) posted Tue, 01 October 2019 at 9:42 PM ยท edited Tue, 01 October 2019 at 9:44 PM
I tried to recreate the problem but couldn't. I don't normally use the camera hands but the guides at the top of the Poser window. Still it should work the same. I noticed you hither and other parameters changed slightly but not enough to get your values. Does it do that with only that scene? How about other PZ3 files?
Weird behavior does happen. I have some poses that only work partially. They are part of a BOUGHT package from another company similar to this one. It's only one pose out of the package but what it does is pose the clothing at the hip, leaves the figure untouched but nothing else. It only does it with one pose package. So far.
Also, that is a very simple scene. Have you tried recreating it from scratch and see what happens? It might be a one time scene corruption.
Also thanks for the freebies, Ockham! Much appreciated. I always give you a top rating. 5 Stars.
bwldrd ( ) posted Wed, 02 October 2019 at 12:00 AM
I had this happening every once in a while in 11, and other versions of poser, no idea what causes it, but had to restart poser to correct it.
Consider me insane if you wish, but is your reality any better?
ockham ( ) posted Fri, 04 October 2019 at 6:52 PM
After more usage, this doesn't happen in most scenes. It's just peculiar to that one scene, or maybe the initial placement of the cameras.
My python page
My ShareCG freebies
nerd ( ) posted Fri, 04 October 2019 at 7:05 PM
Forum Moderator
Is the camera parented to something? I've seen this happen with cameras parented to things other than the universe.
ockham ( ) posted Tue, 08 October 2019 at 10:53 AM
No, the original complaint is still valid. Here's the pattern:
Every time I start a new scene, the cameras go crazy on the first adjustment. It's not just the 'hand' controls, a dial adjustment to the dolly parms takes them out to infinity immediately.
When I use a scene that was made in previous versions, the problem doesn't happen at all.
My python page
My ShareCG freebies
Little_Dragon ( ) posted Tue, 08 October 2019 at 1:35 PM
Try checking the sensitivity settings on the dolly parms. Perhaps they've ended up with some screwy values.
I don't think they affect the GUI "hand" controls, but it wouldn't hurt to look, anyway.
SamTherapy ( ) posted Tue, 08 October 2019 at 2:01 PM
Crikey! The big hitters are out in force here.
Anyhow, I don't know if this is relevant at all but my cameras keep going crazy, as if my mouse is mistracking. The view will suddenly flip upside down, or continue to rotate, as if I have the flyaround camera selected. Tried using different mice, on different surfaces but always with the same result. Poser is the only thing that exhibits this, too. Nothing else misbehaves in the slightest, well, at least when it comes to using a mouse.
nerd ( ) posted Tue, 08 October 2019 at 5:30 PM
Forum Moderator
Does it happen on every scene or in the default scene. The only other not-content related thing I can think of is IF you're using a tablet and IF you don't have poser's input pref not set to tablet. I vaguely remember seeing this from another cause. I'm going to try to find tthat in the old bug database.
On the bright side if you can control the direction you'd have a stable wormhole. We can explore the other side of the galaxy.
nerd ( ) posted Tue, 08 October 2019 at 7:54 PM
Forum Moderator
The bug I was thinking of had to do with geometry that contained not-a-number vertex values. Seems unlikely to be related to this.
