Sat, Feb 1, 4:52 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Performing further wxApp iniitalisation within poser.WxAuiManager environs
an0malaus ( ) posted Mon, 14 October 2019 at 4:31 AM · edited Sat, 01 February 2025 at 4:50 PM
I have a problem. There are many ways to build user interfaces with wxPython, but due to the lack of development in this area of Poser to date, we are currently stuck with such old versions that many options are buggy or simply do not work at all on either Windows or MacOS or both.
I am encountering many code examples which simply do not and possibly cannot work within Poser Python, because they rely on the wxApp() initialisation to instantiate functions like wx.BLACK and wx.WHITE that seem to be heavily relied upon by various flavours of UI managers within wxPython.
My particular need was to have ToolTips on wx.Notebook page tabs, but they are not supported. The wx.lib.agw.aui.AuiNotebook is purported to support this, but cannot be accessed, because it relies on wx.App() having initialised. Poser has its own alternative, poser.WxAuiManager(), but does not make the frequently used colour functions available (wx.BLACK & wx.WHITE, etc.), throwing errors whenever these are referenced.
wx.App() cannot be used at all, as it's event loop is in conflict with Poser's own and will immediately crash Poser to the desktop if called.
I have found certain magic incantations that supposedly can perform the necessary initialisation/instantiation, but they are not designed for use in Poser, so do not work.
wxWidgets How to initialze wxApp...
This link also appears specifically relevant wxPython 2.6 Migration Guide in its Module Initialisation section.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
adp001 ( ) posted Mon, 14 October 2019 at 6:36 AM · edited Mon, 14 October 2019 at 6:40 AM
Maybe you can create your own ToolTip handling with (wx.window).SetTooltip(...). https://docs.wxpython.org/wx.ToolTip.html#wx.ToolTip
an0malaus ( ) posted Mon, 14 October 2019 at 7:33 AM
Thanks Freddi, I think I may have found the solution by trawling through some of SnarlyGribbly's scripts. It appears that
import wx, wx.aui, wx.lib.agw.aui as aui
wx.StockGDI._initStockObjects()
is the thing which finally initialises what I need, since now:
>>> wx.WHITE
wx.Colour(255, 255, 255, 255)
I get what I expect from that initialised name, rather than just wx.Colour(), which is no use to man or beast.
Off to plug it in and check it out.
My ShareCG Stuff
adp001 ( ) posted Mon, 14 October 2019 at 11:26 AM
wx.WHITE and wx.BLACK are no functions.
The following in my Linux-Environment:
import wx
print(wx.version())
print(wx.WHITE)
results in:
3.0.2.0 gtk3 (classic)
Traceback (most recent call last):
    print(wx.WHITE)
  File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_gdi.py", line 278, in __str__
    def __str__(self):                  return str(self.Get(True))
  File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_gdi.py", line 266, in Get
    return _gdi_.Colour_Get(*args, **kwargs)
TypeError: in method 'Colour_Get', expected argument 1 of type 'wxColour *'
Seems Poser-Python is not guilty here :)
an0malaus ( ) posted Mon, 14 October 2019 at 12:07 PM
Gotta compare eggs with eggs. It's a different wx version, and there were substantial changes between wx 2.9.1 and 3.0. Probably even moreso between wxMAC and wxGTK.
Anyway, the kind of error you're seeing is exactly the same as what I had if I tried to instantiate a wx.lib.agw.aui.AuiNotebook, without having a call to wxApp() (Prohibited in Poser as it breaks Poser's own event loop). Fortunately, the call wx.StockGDI._initStockObjects() is exactly the thing that was missing to correctly define wx.WHITE and all the other class objects that normally happens in wxApp(). Screen Shot 2019-10-14 at 11.56.56 pm [EDITED].png
Here's my working AuiNotebook example.
My ShareCG Stuff
adp001 ( ) posted Mon, 14 October 2019 at 5:47 PM
Here is what wx.StockGDI._initStockObjects() does: https://github.com/wxWidgets/Phoenix/blob/master/src/stockgdi.sip
Seems a good idea to call it with every wx PoserPython script.
an0malaus ( ) posted Tue, 15 October 2019 at 12:15 AM
Yes, exactly, it's the missing magic that Poser scripts need in the absence of being able to instantiate wxApp() which does that very thing we need.
It really ought to be in an example script provided with Poser script samples.
My ShareCG Stuff
Snarlygribbly ( ) posted Tue, 15 October 2019 at 2:11 PM
adp001 posted at 8:10PM Tue, 15 October 2019 - #4367113
I have made templates for regular Poser scripts and Poser addon scripts, and this is one of the lines that I consider essential enough to feature in my templates.
Free stuff @ https://poser.cobrablade.net/
an0malaus ( ) posted Tue, 15 October 2019 at 6:49 PM
Thanks, Snarly. Was trying to catch you for a question on mat file image conflicts between simple and shader-tree which seems to affect EZDome, but it'll wait.
My ShareCG Stuff
