Mon, Jan 6, 9:09 PM CST
Renderosity Forums / The MarketPlace Wishing Well
Welcome to the The MarketPlace Wishing Well Forum
Forum Moderators: Staff
The MarketPlace Wishing Well F.A.Q (Last Updated: 2025 Jan 06 1:53 am)
Have an idea for a MarketPlace product? Would you like to let the MarketPlace Merchants know?
This is the place!
Make sure you check The Product Showcase Forum and The Product Showcase Art Gallery.
Subject: Products I'd like to see
wolfmanjim ( ) posted Thu, 03 October 2019 at 9:01 AM ยท edited Mon, 06 January 2025 at 9:06 PM
It's been a while since I've posted here, but I have a few items I would like to see for Poser.
  1. A sport climbing wall.
  2. Religious jewelry. There are many crosses, but how about a set with Magen David, Thor's Hammer, Hindu Om. Islamic crescent and Buddah's wheel?
forester ( ) posted Wed, 16 October 2019 at 2:32 AM
Two climbing walls - one interior, and one outdoors - should be in the Marketplace around the end of this week. I just have to place all the climbing jugs on the walls.
These will be in *.obj file format.
wolfmanjim ( ) posted Wed, 16 October 2019 at 10:46 AM
forester posted at 10:43AM Wed, 16 October 2019 - #4367255
Looks good! I'd like to see more overhangs in the course, if possible. But hey, I'll be buying it either way!
forester ( ) posted Wed, 16 October 2019 at 11:13 AM
Thanks for the feedback. I was wondering about how difficult to make this. So, I will re-make it to include overhangs.
And anything else you'd like to see in these two versions?
Got to run errands today, so, the changes will delay this getting into the Marketplace by Friday. But I'll be happy to do it. By the way, despite the lighting, this one will be the interior version. Also, should I also add an optional mattress and because it is interior, should I add a suspended safety line and carabiner? I'd built one like this. Should I add it as optional and you can position it if you like ???? Biner.jpg
wolfmanjim ( ) posted Thu, 17 October 2019 at 12:41 PM
forester posted at 12:40PM Thu, 17 October 2019 - #4367308
The line looks terrific and I love it!
forester ( ) posted Thu, 17 October 2019 at 1:05 PM ยท edited Thu, 17 October 2019 at 1:08 PM
I rebuilt the interior version with two overhangs. Kind of a balancing act between making decent overhangs and the overall look of the place. Also trying to allow for some decent camera shots. Overhangs are based on mapped out courses. Moderate difficulty level for the overhangs. Climbing holds are/will be "jugs", a few "pinches", a couple of "pockets", "edges" and a few "slopers."
If you have any changes you'd like to see in this, please let me know as soon as possible. Otherwise, I'll call this version "final." (Roof is removed in these renders to allow light into the place.)
And your feedback really helps.
EClark1894 ( ) posted Tue, 22 October 2019 at 7:20 AM
Instead of building two versions, why not one version and just include morphs to add more "jugs" if needed? That way, the user could increase the difficulty if wanted?
forester ( ) posted Sun, 27 October 2019 at 9:42 PM
Good question! Mostly, the answer is that I am ignorant of Poser and really don't know what a "morph" is.
I ended up building a single version of this facility, an indoor facility (and not the outdoor climbing structure). The indoor climbing hall has been submitted to the Store and should be available in one or two days.
The reason for the single version is that mapping out various climbing courses on the three walls, and placing the 75 unique climbing holds required a lot more time than I'd anticipated. The final model has climbing courses for adults and children, and for beginners and more experienced climbers. The total number of climbing holds is just under 300, and each was somewhat time-consuming to place correctly against the contours of the walls.
I'm completely ignorant of how someone would do this with morphs, although I infer that the idea is that the artist could moved any and all of them to suit his or herself, per scene. Its a good idea, but believe me, just getting 300 climbing holds on this model more or less correctly required about three days of work.
The final model is shaped in such a way, and has a removable roof to allow as many decent camera angles as possible. The overhead brace, pully and safety line is an independent object so that it can be duplicated and/or moved around to wherever seems reasonable. The mattress also is a separate object.The human reference figure is just a simple scale guide and can be discarded.
forester ( ) posted Sun, 27 October 2019 at 9:47 PM ยท edited Sun, 27 October 2019 at 9:49 PM
There are carabiners bolted to the wall in the correct locations on the overhangs, and one is bolted to the upper right hand side of the rear wall. (In addition to the normal climbing holds.) The types of climbing holds are "jugs", "pinches" "slopers", "edges" and "pockets."
As my day job allows, I'll build an outdoor climbing structure as well. We have some great ones at the base of every ski area and in every college and university here in Colorado, so there is lots of inspiration for this kind of thing. I won't really rest until I've modelled one of those as well.
forester ( ) posted Mon, 28 October 2019 at 11:58 PM
Its in the Store.........
generation2235 ( ) posted Sun, 03 November 2019 at 9:44 AM
I am definitely on the lookout for a few medical-based items, to work in Poser 11. Some big, some small.
  • Mammogram machine
  • CT, or 'Catscan' system
  • Vitals monitor, for taking blood pressure, temperature and heartrate of a patient
  • Electrocardiograph unit with sticker probes for V4 & M4
  • Portable blood pressure checker with posable cuff for V4 & M4
Please let me know if any of these items might already be available for Poser 11 and where I can obtain them, or whether these highly-marketable items could be created for use in Poser 11.
Thanks so much.
forester ( ) posted Sun, 03 November 2019 at 11:05 AM ยท edited Sun, 03 November 2019 at 11:15 AM
The correct place for making requests like these is in Renderosity's "Marketplace Wishing Well" forum thread. https://www.renderosity.com/mod/forumpro/?forum_id=1244
Apologies, I should have mentioned this before engaging in the attempt to fulfill 'wolfmanjim's' request.
generation2235, you'll have much better luck if you repeat this request in that forum. It will just get lost here.
...... I believe there is little here that meets your "wish list." The best place I know to get inexpensive models of your first three items is at "CGTrader.com" Use "hospital" in your search terms. There are at least three versions of your first three items in three packages, all at a good price. I've used all of these myself for earlier work with a client in the medical profession. They are good models.
You'll want these in *.obj file format if you are going to use them in Poser. Then, follow up with a Renderosity "Marketplace Wish Well" request for the Poser poseable cuff and portable blood pressure checker, etc. These should be no great problem for a model-builder and you'll probably get what you need in short order. (I would help you if I could, but I know nothing of Poser - am just a simple Maya model-builder.)
generation2235 ( ) posted Tue, 05 November 2019 at 4:25 PM
Thanks.
I will copy and paste the contents of my initial post over to the Wishing Well thread.
generation2235 ( ) posted Tue, 05 November 2019 at 4:28 PM
Actually the page at https://www.renderosity.com/mod/forumpro/?forum_id=1244 says that 'We cannot find that forum in our records'
forester ( ) posted Wed, 06 November 2019 at 3:14 PM
Strange, using that link yesterday takes me to the site, but using it today takes me to the top of all the forums.
Anyhow, my apologies. Were you able to locate The Marketplace Wishing Well forum on your own? If not, you could start a new thread in this forum, so that other vendors (Poser specialists) will see your request. I'm afraid that they won't notice it at the bottom of this thread about sport climbing walls.
wolfmanjim ( ) posted Fri, 15 November 2019 at 7:54 AM
forester posted at 7:54AM Fri, 15 November 2019 - #4368578
Bought it!
wolfmanjim ( ) posted Fri, 15 November 2019 at 8:14 AM
generation2235 posted at 8:14AM Fri, 15 November 2019 - #4369055
  • Mammogram machine
Thanks so much.
I wish folks paid any attention to the Wishing Well.
Parallax3DArt ( ) posted Sun, 17 November 2019 at 8:19 PM
I have some hindi related jewelry in my store - multi generation & unisex.
https://www.renderosity.com/mod/bcs/satori-jewelry-set/137523/
