Wed, Nov 20, 2:47 AM CST
Subject: Texture problem in P11.2
jartz ( ) posted Mon, 21 October 2019 at 9:40 PM · edited Wed, 20 November 2024 at 12:36 AM
I'm trying to add a texture to a obj. clothing figure, and I get this result. Just the color texture, but without the design I created. Has anyone encounter this?
Thanks.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Miss B ( ) posted Mon, 21 October 2019 at 10:02 PM
Hey Jartz, have you seen the same thing when rendered, or is that just in Preview mode?
The reason I ask is, my Laptop's integrated CPU doesn't use all the OpenGL options available, so I often don't see the textures as they look once I render. That said, however, I don't think I've seen a solid color when there's a texture. The texture just doesn't look the same in Preview mode, as it does once rendered..
_______________
Butterfly Dezignz
jartz ( ) posted Mon, 21 October 2019 at 10:06 PM · edited Mon, 21 October 2019 at 10:16 PM
That's a render, not in Preview Mode. It's when I try to render it, I get that effect. I'll try to see what I can do with other objects/props with said texture.
Footnote: Maybe it's something to do with what I'm doing in Marvelous Designer. When I put my texture in the box primitive. It shows up, it's when I put it in my MD object, the texture doesn't, all I get is the color texture, not the design.
Still trying to figure this out. I never had this problem in version 11.1, so...
hborre ( ) posted Mon, 21 October 2019 at 10:07 PM
This object probably is not UV mapped for one. Try reducing your U_ and V_ Scales to a lower value until you get something acceptable.
jartz ( ) posted Mon, 21 October 2019 at 10:18 PM
hborre posted at 10:18PM Mon, 21 October 2019 - #4367908
I think I got it now. The thing is, I have to scale it to a higher value.
hborre ( ) posted Mon, 21 October 2019 at 10:36 PM
That's fine as long as you can match the pattern to your object for a better render.
Miss B ( ) posted Tue, 22 October 2019 at 12:26 PM
Ahhh, glad to hear you got it worked out. 🙂
_______________
Butterfly Dezignz
