Community Center F.A.Q (Last Updated: 2024 Oct 21 3:28 pm)
I can't help with the serial issue, but I would like to ask for any tips you might offer others of us who would install older versions of Poser in newer windows. I would like to keep my Poser 6 (and even Poser 4 Pro Pack) usable if possible - even if it's just to keep using the Meta-Nurbs script expansion that stopped working in P7).
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
theKageRyu posted at 11:34AM Wed, 30 October 2019 - #4368669
Right-click on the Poser shortcut and set Compatibility
But it would seem that the serial number on the Miki CD envelope doesn't work? I keep getting the error message that the serial number entered isn't valid yet it's identical to what's on the label stuck on the envelope...what gives? The other two CD's installed fine
