Sun, Jan 5, 10:03 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 9:32 pm)
Subject: Need Verification on Possible Eye Material Bug
FightingWolf ( ) posted Thu, 21 November 2019 at 9:07 PM ยท edited Sun, 05 January 2025 at 9:36 PM
Problem: Eye Surface Material doesn't change when I select different eye materials Figure used: V4
So I've spent all day working on material settings and I realized that my not all of the eye materials are changing when I load different eye materials. What is happening is that some of the Eye Surface material settings remain even through I'm loading different eye materials. It's a big headache for me because the only way I can be sure that I have all of the materials for what I selected is start over with clean load of the default Victoria 4
Is anyone else having this problem? You would need to watch the eye surface settings to see if it changes when a different eye mat is loaded.
structure ( ) posted Thu, 21 November 2019 at 9:46 PM
Forum Coordinator
Not all older materials ( and possibly some newer materials by inexperienced creators ) contain all the material zones for the eyes.
Locked Out
AmethystPendant ( ) posted Fri, 22 November 2019 at 3:52 AM
@fightingWolf I still think it is an issue with Poser not being able to find maps, you mentioned you had new hardware etc and you aren't having this problem on other computers. It is possible that you haven't copied, for example, the textures subfolder for a particular material. What search depth have you set in preferences?
